Model.trim_elements2#
- Model.trim_elements2(base_element_collection, trim_element_collection, mode, num_layers, feature_angle, base_component)#
Trims 2D elements using 1D or 2D elements.
- Parameters:
base_element_collection (Collection) – The collection containing the element entities of the base.
trim_element_collection (Collection) – The collection containing the element entities used for trimming.
mode (int) –
Flag to indicate how to connect elements when the trimming elements are 2D elements and the boundaries of the selection consist of multiple loops.
0 - Keep internal elements.
1 - Elements inside internal loops are removed. For example, no elements inside washer.
num_layers (int) –
Flag to indicate the number of surrounding element layers will be taken into account for remeshing.
0 - No remeshing.
1 - All elements on base_element_mark will be remeshed.
feature_angle (double) – Parameter used to define feature edge in remeshing.
base_component (int) –
Flag to indicate if the imprinted elements should be organized to the same component as the base elements.
0 - Keep original organization for imprinted elements.
1 - Organize all imprinted elements to the same component as the base elements.
Example#
Trim elements 1 - 100 with elements 500 - 550 , remove elements from within internal loops , with remeshing , a feature angle of 30 and keep the original organization#import hm import hm.entities as ent model = hm.Model() # Creating the collection of the base elements filter_base_elements = hm.FilterByEnumeration(ent.Element, list(range(1, 101))) collection_base = hm.Collection(model, filter_base_elements) # Creating the collection of the trimming elements filter_trimming_elements = hm.FilterByEnumeration(ent.Element, list(range(500, 551))) collection_trimming = hm.Collection(model, filter_trimming_elements) model.trim_elements2( base_element_collection=collection_base, trim_element_collection=collection_trimming, mode=1, num_layers=1, feature_angle=30, base_component=0, )
