Model.CE_FE_RegisterSharedEntitiesByMark#
- Model.CE_FE_RegisterSharedEntitiesByMark(collection, existing_entities)#
Registers pre-existing entities to multiple connectors.
Note that a single entity can be registered with multiple connectors.
- Parameters:
collection (Collection) – The collection containing the connector entities to register to.
existing_entities (CollectionSet) – The set of collections containing possibly multiple type of entities.
Example#
Register pre-existing FE to connectors with IDs 1-10#import hm import hm.entities as ent model = hm.Model() # Change connectors 1-10 to the user control mode: ce = hm.Collection(model, ent.Connector, list(range(1, 11))) model.CE_SetSpecificDetail(connector_collection=ce, detail_type=2, integer_value=1, double_value=0.0) # Create the necessary collection set to register collections of multiple types of entities: collection_set = hm.CollectionSet(model) # Create collection of component entity with ID 3 and add to collection set: component_1 = hm.Collection(model, ent.Component, [3]) collection_set.set(component_1) # Create collection of property entity with ID 7 and add to collection set: property_1 = hm.Collection(model, ent.Property, [7]) collection_set.set(property_1) # Create collection of material entity with ID 8 and add to collection set: material_1 = hm.Collection(model, ent.Material, [8]) collection_set.set(material_1) # Create collection of set entity with ID 12 and add to collection set: set_1 = hm.Collection(model, ent.Set, [12]) collection_set.set(set_1) # Create collection of group entity with ID 14 and add to collection set: group_1 = hm.Collection(model, ent.Group, [14]) collection_set.set(group_1) # Create the collection containing the connector entities with IDs 1-10: ce = hm.Collection(model, ent.Connector, list(range(1, 11))) # Register the entities with connector 7: model.CE_FE_RegisterSharedEntitiesByMark( collection=ce, existing_entities=collection_set ) # Change connectors 1-10 back to normal control mode (optional): ce = hm.Collection(model, ent.Connector, list(range(1, 11))) model.CE_SetSpecificDetail(connector_collection=ce, detail_type=2, integer_value=0, double_value=0.0)
