Model.hideentitybymark#
- Model.hideentitybymark(collection_set, showcomps=False, elements_off=False, geometry_off=False)#
Turns off the display of a mark of entities.
- Parameters:
collection_set (CollectionSet) – The set of collections containing possibly multiple type of entities to turn off the display. All entities with a display state on the
collection_set, regardless of entity type, are considered.showcomps (bool) – This indicates that components in which elements/geometry are referred will also be shown when you show elements/geometry. If not provided, only specified elements/geometry are shown.
elements_off (bool) – This indicates that elements in the specified collectors should not be considered. If not provided, the default is to consider elements in the specified collectors.
geometry_off (bool) – This indicates that geometry in the specified collectors should not be considered. If not provided, the default is to consider geometry in the specified collectors.
Examples#
Hide geometry and elements for components with IDs 1-3#import hm import hm.entities as ent model = hm.Model() # Creating the collection set comps_collection = hm.Collection(model, ent.Component, list(range(1, 4))) ent_collectionset = hm.CollectionSet(model) ent_collectionset.set(comps_collection) model.hideentitybymark(collection_set=ent_collectionset)
Hide all components and load collectors, consider only elements#import hm import hm.entities as ent model = hm.Model() # Creating the collection set comps_collection = hm.Collection(model, ent.Component) loadcols_collection = hm.Collection(model,ent.Loadcol) ent_collectionset = hm.CollectionSet(model) ent_collectionset.set(comps_collection) ent_collectionset.set(loadcols_collection) model.hideentitybymark(collection_set=ent_collectionset,geometry_off=True)
