Model.elementtestinterangle#
- Model.elementtestinterangle(collection, testangle, trias, outputcollection, wantmin, dimension, contour, title)#
Tests 2 and 3 dimensional elements for whether or not they pass the interior angle element quality check, and puts those that fail on the specified
outputcollection.- Parameters:
collection (Collection) – The collection containing the element entities to test.
testangle (double) – The value to use as a threshold beyond which elements should be considered to have failed the test (in degrees).
trias (int) – A nonzero value indicates to test trias or tria faces, as opposed to quads or quad faces.
outputcollection (Collection) – The collection containing the failed element entities.
wantmin (int) – A nonzero value indicates to check if the element’s smallest angle is less than the threshold, as opposed to its largest angle being greater than the threshold.
dimension (int) –
A code telling to measure the dimension of:
1 - Measure 1D elements.
2 - Measure 2D elements.
4 - Measure 3D elements.
contour (int) –
A code telling if should:
0 - Display the results of the test normally.
1 - Display the elements color coded by their ratings.
2 - Build a histogram showing the distribution of ratings.
title (hwString) – The title to label the curve in the histogram.
Example#
Test all displayed elements for an interior angle value less than 135.0#import hm import hm.entities as ent model = hm.Model() elems1 = model.CreateCollectionByDisplayed(ent.Element) elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([]))) model.elementtestinterangle( collection=elems1, testangle=135.0, trias=0, outputcollection=elems2, wantmin=0, dimension=2, contour=0, title="Quad Max Angle" )
Note
The details of the interior angle element quality check can be found in the online help for the Check Elements panel.
