Model.rbody_mesh#
Model.rbody_mesh(collection, min_size, max_size, max_chordal, max_angle, remesh, mesh_type, elem_comp, elem_order, shared_edge_flag)#
Creates a rigid body mesh on surfaces.
Parameters:
  • collection (Collection) – The collection containing the surface entities to mesh.
  • min_size (double) – The minimum element size.
  • max_size (double) – The maximum element size.
  • max_chordal (double) – The maximum allowed chordal deviation.
  • max_angle (double) – The maximum feature angle.
  • remesh (int) –
    0 - Delete existing elements before mesh
    1 - Do not delete existing elements before mesh
  • mesh_type (int) –
    0 - Trias
    1 - Mixed
  • elem_comp (int) –
    0 - Organize elements in current component
    1 - Organize elements in surface component(s)
  • elem_order (int) –
    1 - First
    2 - Second
  • shared_edge_flag (int) –
    For options 1-6 :
    0 - Allow node movement across shared edges, and ignore chordal deviation. With this option connectivity with existing mesh is broken.
    1 - Do not allow node movement across shared edges, and ignore chordal deviation. With this option connectivity with existing mesh is broken.
    2 - Allow node movement across suppressed edges, and ignore chordal deviation. With this option connectivity with existing mesh is broken.
    3 - Allow node movement across shared edges, and keep chordal deviation. With this option connectivity with existing mesh is broken.
    4 - Do not allow node movement across shared edges, and keep chordal deviation. With this option connectivity with existing mesh is broken.
    5 - Allow node movement across suppressed edges, and keep chordal deviation. With this option connectivity with existing mesh is broken.
    6 - Do not allow node movement across shared edges, do not allow edge swap in cleanup, and keep chordal deviation. With this option connectivity with existing mesh is broken.
    10 - Same as option 0 but keep connectivity with existing mesh
    11 - Same as option 1 but keep connectivity with existing mesh
    12 - Same as option 2 but keep connectivity with existing mesh
    13 - Same as option 3 but keep connectivity with existing mesh
    14 - Same as option 4 but keep connectivity with existing mesh
    15 - Same as option 5 but keep connectivity with existing mesh
    16 - Same as option 15 and allow mesh refining to avoid intersections
    Note
    For shared_edge_flag, options 7 - 9 are currently unavailable.
Example#
Create a first order rigid body mesh on surfaces with IDs 1 - 10 , with minimum size of 0.5 and maximum size of 30.0#
import hm
import hm.entities as ent
model = hm.Model()
surf_collection = hm.Collection(model, ent.Surface, list(range(1, 11)))
model.rbody_mesh(
    collection=surf_collection,
    min_size=0.5,
    max_size=30.0,
    max_chordal=0.1,
    max_angle=15,
    remesh=1,
    mesh_type=1,
    elem_comp=1,
    elem_order=1,
    shared_edge_flag=2,
