Model.createsolverkeyword#
- Model.createsolverkeyword(keyword, type=EntityFullType(), includeFile='')#
This function creates an entity that has a mapped solver keyword by just specifying the keyword. The keywords are sourced from the solver browser.
- Parameters:
keyword (hwString) – The string specifying the keyword.
type (EntityFullType) – Specifies the entity type if the mapping is predetermined. If the same keyword is featured in two different entity types, then the entity type can be specified.
includeFile (hwString) – Specifies the include file name in which this keyword is to be created. If include file name is not specified it will be created in current include.
Example#
Create CONTACT entity in OptiStruct#import hm import hm.entities as ent model = hm.Model() model.createsolverkeyword(keyword="CONTACT")
Create *SURFACE INTERACTION in Abaqus#import hm import hm.entities as ent model = hm.Model() model.createsolverkeyword(keyword="*SURFACE INTERACTION")
Create *NSET in Abaqus in include “load_data”#import hm import hm.entities as ent model = hm.Model() model.createsolverkeyword(keyword="*NSET", includeFile="load_data")
