Model.CE_AddLinkEntitiesWithRules#
Model.CE_AddLinkEntitiesWithRules(connector_collection, entity_collection, entity_state, ce_rules, ce_le_rule, tolerance_flag, tolerance, num_ents)#
Updates connectors at the specified locations with rules.
Parameters:
  • connector_collection (Collection) – The collection containing the connector entities to update.
  • entity_collection (Collection) – The collection containing the entities to use as links.
  • entity_state (unsigned int) –
    The state of the link entities. Valid values are:
    0 - Geometry.
    1 - Elements.
  • ce_rules (unsigned int) –
    Flag indicating when to make the links. Valid values are:
    0 - Now.
    1 - At realize.
  • ce_le_rule (unsigned int) –
    Flag indicating how to make the links. Valid values are:
    0 - None.
    1 - Use ID.
    2 - Use name.
  • tolerance_flag (unsigned int) –
    Flag indicating whether to use the default tolerance. Valid values are:
    0 - Use default.
    1 - Use specified value.
  • tolerance (double) – Used to add entities only within the given tolerance from the specified connector.
  • num_ents (int) – Number of entities to add/update connector (connectors thickness (2T, 3T, etc.) value).
Example#
Update connectors with IDs 1 and 2 to add the nearest two out of four components specified, using a tolerance of 1.0. Components will be linked by IDs#
import hm
import hm.entities as ent
model = hm.Model()
    model.CE_AddLinkEntitiesWithRules(
    connector_collection=hm.Collection(model, ent.Connector, [1, 2]),
    entity_collection=hm.Collection(model, ent.Component, [21, 23, 24, 27]),
    entity_state=1,
    ce_rules=1,
    ce_le_rule=1,
    tolerance_flag=1,
    tolerance=1.0,
    num_ents=2,
