Model.triangle_clean_up#
Model.triangle_clean_up(collection, criteria_string, graphicsDB=0)#
Fixes sliver/bad quality elements which fail the user-defined aspect ratio.
Parameters:
  • collection (Collection) – The collection containing the element entities.
  • criteria_string (hwString) –
    There are two possible criteria that can be included in the string:
    • aspect=<value>
    The elements failing this given aspect ratio value will be fixed. The aspect ratio is defined as the minimum height/longest edge.
    • height=<value>
    The elements failing this given element height value will be fixed. The minimum height is defined as shortest distance from a node to opposite edge.
  • graphicsDB (int) – Reserved for future development.
Example#
Correct all elements fail aspect ratio of 8 or height of 3#
import hm
import hm.entities as ent
model = hm.Model()
# Creating collection containing all the components
input_collection = hm.Collection(model, ent.Component)
model.triangle_clean_up(
    collection=input_collection, criteria_string="aspect=8 height=3"
