Model.hm_modelcheckneedscorrection#
- Model.hm_modelcheckneedscorrection(check_display_name)#
Returns 1 if an auto correction is required for a given check. Checks with auto correction should be run and have failed entities before running this function.
- Parameters:
check_display_name (hwString) –
The GUI display name of the check. This is case sensitive.
If not specified, then all checks in the current profile are considered and if any of them require correction and support auto correction, 1 will be returned.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:needsCorrection (bool)
Example#
Get the correction status for the “ Unused materials “ check#import hm import hm.entities as ent model = hm.Model() _,result = model.hm_modelcheckneedscorrection(check_display_name="Unused materials") print("needsCorrection",result.needsCorrection)
