Model.xyplotonecurvemath#
Model.xyplotonecurvemath(function, outputname, xbased, factor)#
Performs a math function on a curve.
Parameters:
  • function (int) – The function being performed (7-14)
  • outputname (hwString) – The name of the output curve.
  • xbased (int) –
    0 - If the function should work on the y coordinate.
    1 - If the function should work on the x coordinate.
  • factor (double) – The factor to be used in the calculation.
Example#
Perfome a math function on y - coordinate of a curve#
import hm
import hm.entities as ent
model = hm.Model()
model.xyplotonecurvemath(function=7, outputname="math1", xbased=0, factor=0.2)
