Model.writemodelcheckresultfile#
- Model.writemodelcheckresultfile(filename, filetype)#
Writes out model check results to a file.
- Parameters:
filename (hwString) – The full path and name of the file to write. By default is given a .txt extension if not specified.
filetype (int) –
0 or 1 - Only the failed count associated with the checks is written out.
2 - Entity type, failed count, and count of entities in the model are written against the check.
3 - Along with the above information, the time taken to run each check is also written out.
4 - A detailed CSV report with entity type, run status, failed count, comments, and failed entity IDs against each check is generated.
5 - Writes out failed count against only failed checks flagged under the user status column.
Example#
Write results to the file C:/temp / check_results.txt#import hm import hm.entities as ent model = hm.Model() model.writemodelcheckresultfile(filename="C:/temp/check_results.txt", filetype=1)
