Model.change_edgedensities#
Model.change_edgedensities(collection, mode, density, refedge)#
Changes the densities of selected surface edges and remeshes the adjacent surfaces, according to the specified mode. This is an automesh function.
Parameters:
  • collection (Collection) – The collection containing the input surface entities.
  • mode (int) –
    The method used to assign the density to the surface edges:
    1 - Set edge density to the density value.
    2 - Increment/decrement the edge density by the density value. A positive density will increment while a negative density will decrement.
    3 - Set edge density to be the same as on reference edge refedge.
  • density (int) – The density value to assign to the surface edges on collection. Valid with mode 1 and 2.
  • refedge (Entity) – The line entity defining the edge used when mode =3.
Examples#
Set edge density to 10 on edge with ID 208#
import hm
import hm.entities as ent
model = hm.Model
model.change_edgedensities(
    collection=hm.Collection(model, ent.Line, [208]), mode=1, density=10, refedge=None
Increment by 1 density on edge with ID 208#
import hm
model = hm.Model
    collection=hm.Collection(model, ent.Line, [208]), mode=2, density=1, refedge=None
Decrement by 2 densities on edges with ID 208 and 209#
import hm
model = hm.Model
    collection=hm.Collection(model, ent.Line, [208, 209]), mode=2, density=-2, refedge=None
import hm
model = hm.Model
    collection=hm.Collection(model, ent.Line, [229, 222, 219]), mode=3, density=0, refedge=ent.Line(model,211)
