Model.blockwallreset# Model.blockwallreset(name)# Deletes all walls from a finite difference block. Parameters: name (hwString) – The name of the block from which all walls are to be removed. Example# Remove all walls from block with name “block1”# import hm model = hm.Model() model.blockwallreset(name="block1")
