Model.applyresultsasloads#
Model.applyresultsasloads(collection, multiplier, datatype, loadtype, loadcomp)#
Create loads at an entity’s nodes based on a models result information. Requires the result data to be loaded via the deprecated HyperMesh post-processing infrastructure.
Parameters:
  • collection (Collection) – The collection containing the entities with nodes.
  • multiplier (double) – The multiplier to apply to the result.
  • datatype (hwString) – The data type.
  • loadtype (hwString) –
    The type of load to create.
    For vector datatypes:
    forces
    moments
    velocities
    accels
    For scalar datatypes:
    temp temp
    flux flux
  • loadcomp (hwString) –
    The load component. The value is only used for vector data types; it should be set to 0 for scalar data types. It may be specified as one of the following:
    total
    comp1 comp1
    comp2 comp2
    comp3 comp3
    0
Example#
Apply load results use Applied Forces from Subcase 1 in the .res file model.res use total component to all nodes#
import hm
import hm.entities as ent
model = hm.Model()
model.applyresultsasloads(collection=hm.Collection(model,ent.Node),multiplier=1.0,datatype="Applied Forces",loadtype="forces",loadcomp="total")
