Model.createfmvss201u_start#
- Model.createfmvss201u_start(vehicledir, method, seattraveldist=127.0, wsoffset=0.0, weatherstrippingoffset=0.0, exteriorpartsids=hwIntList(), interiorpartsids=hwIntList(), windshieldpartsids=hwIntList(), sgrp=hwTriple(0.0, 0.0, 0.0), sgrprear=hwTriple(0.0, 0.0, 0.0), testlabcsv='', side=0)#
Defaults for marking lines and impact points on the upper interior parts of a vehicle. The vehicle front should be pointing in +X or -X direction.
The function can be followed by none or many
Model.createfmvss201u_createpoints()functions and should finally be followed by theModel.createfmvss201u_end()function.- Parameters:
vehicledir (int) –
-1 - Vehicle forward direction is toward negative x-axis.
1 - Vehicle forward direction is toward positive x-axis.
method (int) –
0 - Automatic marking based on selections.
1 - Read and mark design points from test lab import file.
seattraveldist (double) – The value of seat travel distance to calculate cgf1 and cgf2 points from
sgrp.wsoffset (double) – The windshield offset double value if windshield does not contact the interior roof in the work model.
weatherstrippingoffset (double) – The weather stripping offset double value if weather stripping part is not present in the work model.
exteriorpartsids (hwIntList) – The list of component IDs of the exterior roof and pillars of the vehicle. The door components should not be selected.
interiorpartsids (hwIntList) – The list of component IDs of the interior roof and pillars of the vehicle. The door components should not be selected.
windshieldpartsids (hwIntList) – The list of component IDs of the windshield (front) of the vehicle.
sgrp (hwTriple) – The location of front seat seating reference point (SgRP Front) of the vehicle.
sgrprear (hwTriple) – The location of rear seat seating reference point (SgRP Rear) of the vehicle.
testlabcsv (hwString) – The path to the input CSV file.
side (int) –
0 - Left side marking.
1 - Right side marking.
Example#
Mark A Pillar design points, Upper Roof Zone and B Pillar design points#import hm import hm.entities as ent model = hm.Model model.createfmvss201u_start( side=0, vehicledir=-1, method=0, seattraveldist=127.0, weatherstrippingoffset=0.0, wsoffset=0.0, sgrp=[2000.0, -400.0, 500.0], sgrprear=[2800.0, -400.0, 500.0], exteriorpartsids=[10003, 10006], interiorpartsids=[10000, 10004, 10007, 10008, 10010, 10011, 10016, 10017], windshieldpartsids=[10001], ) model.createfmvss201u_createpoints( pointtype=0, apillarpartsids=10010, ap1=1, ap2=2, ap3=1, apbool=1, ippointid=ent.Node(model,57354) ) model.createfmvss201u_createpoints( pointtype=1, interiorroofpartsids=[10000, 10016, 10017], urbool=1 ) model.createfmvss201u_createpoints( pointtype=2, bpillarpartsids=[10007], bp1=1, bp2=1, bp2pointid=ent.Node(model,52327), bp3=1, bp4=1, bpbool=1, bphighestpointid=ent.Node(model,73386), bpn1pointid=ent.Node(model,52774), bpn2pointid=ent.Node(model,51988), ) model.createfmvss201u_end()
