Model.wadlines_createlines#
Model.wadlines_createlines(integer_array, double_array, line_type)#
Creates multiple wadlines.
Parameters:
  • integer_array (hwIntList) – A list of integers that contains the number of vertices for each polyline.
  • double_array (hwDoubleList) – A list of doubles that contains the 3D coordinates of the vertices for each polyline.
  • line_type (int) –
    0 - Standard line
    1 - Smooth line
Example#
Create 2 wadlines , one with 4 vertices and the other with 3#
import hm
import hm.entities as ent
model = hm.Model()
input_integer_array =[4, 3]
input_double_list =[
        0.0,
        0.0,
        0.0,
        1.0,
        1.0,
        1.1,
        2.0,
        2.0,
        2.0,
        0.0,
        3.0,
        3.0,
        0.0,
        3.3,
        3.3,
        4.0,
        0.0,
        4.0,
        5.0,
        5.0,
        0.0,
model.wadlines_createlines(
integer_array=input_integer_array, double_array=input_double_list, line_type=1
