Model.morphnodesnormalenvelope#
- Model.morphnodesnormalenvelope(m_collection, e_collection, f_collection, n_collection, dist, integ, mbias, fbias, envelope, undisplayed)#
Moves the selected nodes the specified distance normal to the selected elements. The fixed nodes are held in place and the affected elements (or all unfixed nodes in the model if
integis 3 or 6) are stretched according to the value ofinteg.Temporary handles are created for all moving and fixed nodes to determine the stretching of the affected elements. If
integ=0, a general domain is temporarily created for the affected elements. Ifinteg=1, the domains currently in the model are used. Ifinteg=2, 1D, 2D, 3D, and edge domains are temporarily created for the affected elements but the 2D domains are not partitioned. Ifinteg=3, then handle influences are applied using a spatial relationship rather than through a domain. Ifinteg=4, only the selected moving nodes are moved and all others are held fixed. Ifinteg=5, 1D, 2D, 3D, and edge domains are temporarily created for the affected elements and the 2D domains are partitioned. Any handles created due to partitioning are moved based on their distance from the moving and fixed nodes. Ifinteg=6, then handle influences are applied using the Kriging algorithm. Ifinteg=7, then handle influences extend only up to a given distance (ifenvelopeis positive) or a given multiple of the applied perturbations (ifenvelopeis negative) away from the moving nodes.If 100 is added to the value of
integ, the normals of the elements selected for determining the direction of morphing will be averaged with their neighbors, resulting in a smooth distribution of vectors around sharp corners.If 200 is added to the value of
integ, the normals of the elements selected for determining the direction of morphing will be calculated using the “CFD corners” method, resulting in a very smooth distribution of vectors around sharp corners which should prevent mesh folding.The bias factors function as they would for handles except that all moving nodes will have the
mbiasvalue and all fixed nodes will have thefbiasvalue.If
integis set to 3, 6, or 7, nodes on undisplayed elements and components can be morphed, fixed, or excluded depending on the value ofundisplayed.- Parameters:
m_collection (Collection) – The collection containing the moving node entities.
e_collection (Collection) – The collection containing the affected element entities.
f_collection (Collection) – The collection containing the fixed node entities.
n_collection (Collection) – The collection containing the element entities used to determine the normal direction.
dist (double) – The distance the nodes will be moved.
integ (int) –
0 - Free edges (a single general domain) .
1 - Use existing domains.
2 - Inferred edges (1D, 2D, 3D, and edge domains - no partitioning).
3 - Morph all nodes using a proximity algorithm.
4 - Morph all moving nodes and fix the unselected nodes.
5 - Partitioned edges (1D, 2D, 3D, and edge domains with partitioning).
6 - Morph all nodes using the Kriging algorithm.
7 - Morph all nodes within an envelope around the moving nodes.
100 - Smooth the calculated element normals by averaging.
200 - Use the “CFD corners” method to calculate the normals.
mbias (double) – Bias factor of moving nodes.
fbias (double) – Bias factor of fixed nodes.
envelope (double) –
If positive, all nodes beyond the given distance away from the moving nodes will be fixed.
If negative, all nodes beyond a distance calculated by multiplying the total perturbation of each moving node by the absolute value of the envelope and extended away from each moving node will be fixed.
If
integis set to 7, the calculated distance defines an envelope around the moving nodes within which the morphing of those nodes will linearly taper from fully matching the nearest moving node to zero at the edge of the envelope. If any fixed nodes are within the envelope they will also reduce the morphing of nearby nodes.undisplayed (int) –
If
integis set to 3, 6, or 7, nodes which are not displayed can be affected by the morphing. This defines how undisplayed nodes are handled:0 - Morph nodes on undisplayed elements.
1 - Fix nodes on undisplayed elements, they will function just like nodes on the
f_collection.2 - Exclude nodes on undisplayed elements, they will not be morphed nor affect the morphing.
Example#
Move a collection of nodes normal to their attached elements by 5.0 units and stretch all the elements in the model use the exist domains#import hm import hm.entities as ent model = hm.Model() model.morphnodesnormalenvelope( m_collection=hm.Collection(model, ent.Node, [11, 12, 13]), e_collection=hm.Collection(model, ent.Element), f_collection=hm.Collection(model, ent.Node, [21, 22, 23]), n_collection=hm.Collection(model, ent.Element), dist=5.0, integ=1, mbias=1.0, fbias=1.0, envelope=0.0, undisplayed=0, )
