Model.hm_attributelistall#
- Model.hm_attributelistall(value)#
Returns a list of all attribute IDs, names, types or type names for the current template.
- Parameters:
value (hwString) –
The type of list to return. Valid values are:
id - The attributes’ ID.
name - The attributes’ name.
type - The attributes’ type number.
typename - The attributes’ type string.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:Keys valid for
value="name"value (list of strings)
Keys valid for
value="type"value (numpy.ndarray)
Keys valid for
value="typename"value (list of strings)
Keys valid for
value="id"value (numpy.ndarray)
Examples#
List the IDs of all the attributes in the current template#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_attributelistall(value="id") print("List of attrbutes' IDs:", result.value)
List the names of all the attributes in the current template#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_attributelistall(value="name") print("List of attrbutes' names:", result.value)
List the type numbers of all the attributes in the current template#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_attributelistall(value="type") print("List of attrbutes' type numbers:", result.value)
List the type names of all the attributes in the current template#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_attributelistall(value="typename") print("List of attrbutes' type names:", result.value)
