PARAM, LCLGRDST
Bulk Data Entry This parameter can be defined in the local model of a submodeling job, to output the mapping information of each local node to the global nodes, for all the local nodes in a set.
Parameter Values Description
LCLGRDST <GRID_SETID>
GRID_SETID
ID of the grid set in the local model, containing the nodes for which the mapping information is desired.
No default
  1. The mapping information is printed to a .mapdsp file and only when this parameter is defined.
  2. For more information, refer to Global-Local Analysis (Submodeling) in the User Guide.
