PARAM, FFRS
Bulk Data Entry Used to activate the external FastFRS (Fast Frequency Response Solver).
Parameter | Values | Description |
FFRS | <YES,
NO> Defaults:
This solver is very
efficient for a certain class of large modal frequency response
problems, such as those common in automotive NVH analysis.
Note: FastFRS must be installed on the system and the
environment variable FASTFRS_EXE must point to
the FastFRS executable for this parameter to work.
For more details, refer to FastFRS (Fast Frequency Response Solver) in the User Guide. |
