MBDSRF
Bulk Data Entry Defines a multibody deformable surface.
MBDSRF | SRFID | NROW | NCOL | ENDTYPE | NSEGU | NSEGV | |||
G1 | G2 | G3 | G4 | G5 | G6 | etc |
MBDSRF | 1 | 3 | 6 | NATURAL | 100 | 100 | |||
201 | 202 | 203 | 204 | 205 | 206 | 207 | 206 | ||
209 | 210 | 211 | 212 | 213 | 214 | 215 | 216 | ||
217 | 218 |
SRFID | Surface identification number. No default (Integer > 0) |
NROW | Number of rows of nodes. | |
NCOL | Number of columns of nodes. | |
ENDTYPE | Select from:
NSEGU, NSEGV | Number of segments along the U and V coordinates
used to discretize the deformable surface for
animation purposes. No default (Integer > 0) |
G1, G2, … | Row-wise list of nodes. The first NROW IDs form the first row; the second NROW IDs form the second row, and so on. The list must contain a total of NROW*NCOL grid IDs. |
- The
deformable surface is generated using the CUBIC
spline interpolation which requires assumptions on
the second derivative of the interpolating
function at the end of the surface. The keywords
NATURAL,
PARABOLIC and
PERIODIC represent assumptions
defined as follows:
- The MBDSRF element is not supported by the Force Imbalance method of static equilibrium.
- The MBDSRF element does not possess any inherent inertia, stiffness or damping.
- This card is represented as a set in HyperMesh.
