NSML1
Bulk Data Entry Defines lumped non-structural mass for a list of elements or properties.
NSML1 | SID | TYPE | VALUE | ID | ID | ID | ID | ID | |
+ | ID | ID | ID | etc. | |||||
+ | DISTR | DTYPE |
NSML1 | 3 | ELEMENT | 0.06 | 1 | 2 | 3 | 4 |
Alternate Format and Example
NSML1 | SID | TYPE | VALUE | ID | THRU | ID | |||
NSML1 | 3 | ELEMENT | 0.06 | 1 | THRU | 4 |
SID | Non-structural mass set
TYPE | This can be one of the
properties PSOLID, PSHELL,
PCOMP, PBAR,
PBARL, PBEAM,
PBEAML, PROD,
CONROD, PSHEAR,
PTUBE, or MIXED in which
case the list of IDs will refer to properties of the stated type, in
the case of MIXED, it can refer to a list of
properties of a mixture of different types of properties. Or, it can be ELEMENT, in which case the list is of individual element IDs of elements that can have NSM. It can also be of type ELSET, in which case, it is an element SET ID. Note: A mixture of elements of different types can be
included in the list of element IDs. Or, it can also be
can be included in the element sets. 4 No default |
VALUE | A lumped mass value to be
distributed over all the listed elements and elements referencing
listed properties. No default (Real) |
ID | Property, Element ID, or
Element Set ID depending on the TYPE definition.
No default (Integer > 0, "THRU", or <String>) |
DISTR | Flag indicating that the information regarding the type of distribution of mass is to follow. | |
DTYPE | Identifies the type of
distribution of non-structural mass.
- Refer to Non-structural Mass in the User Guide for more information on the use of this card.
- Non-structural mass in this format must be selected by the NSM Subcase Information selector.
- Selection of a mixture of element or property types via the TYPE field is only supported for DTYPE=MASS or VOLUME on the DISTR continuation line. For the default case when DTYPE is blank, referencing a mixture of element or property types does not apply.
- The NSML1 Bulk Data
Entry and its alternate form NSML allow you to allocate and
smear a lumped non-structural mass value to be evenly distributed over a list of
elements.
- Default Distribution (DTYPE=blank on
NSML/NSML1)
The non-structural mass value per unit area, per unit length, or per unit volume to be applied to the elements is:
For the default case when DTYPE is blank, referencing a mixture of different element or property types is not supported.
- Distribution based on Mass/Volume
(DTYPE=MASS/VOLUME
on NSML/NSML1)
The non-structural mass value per unit mass or volume to be applied to the elements is:
Where,- Number of elements in the set
- Value of the lumped mass
- Length of element
- Area of element
- Volume of element
- Mass of element
An important difference between the default distribution (DTYPE=blank) and DTYPE=MASS/VOLUME, is that a mixture of multiple element types (1D, 2D, and 3D elements) can be defined on a single NSML/NSML1 entry when TYPE field is set to ELEMENT/ELSET (mixture of elements) or MIXED (mixture of properties).
NSML/NSML1)
- The value of the non-structural mass does not change during Topology Optimization.
- String based labels allow for easier visual identification, including when being referenced by other entries. For more details, refer to String Label Based Input File.
