- Parameters by Function
List of parameters according to parameter type.
- PARAM, ACMFOSYS
Bulk Data Entry Controls the coordinate system in which the ACM force results are output.
- PARAM, ACMODL12
Bulk Data Entry Restores the ACMODL formulation used in version 12.0 and earlier for the Fluid-Structure Interface.
- PARAM, ACMTXNO
Bulk Data Entry This parameter sets preferences for storage of reduced fluid mass, fluid stiffness, and fluid damping matrices for acoustic superelements.
- PARAM, ACPREFDB
Bulk Data Entry Specifies the reference acoustic power value used to calculate Acoustic Power (ACPOWER) in decibels (dB).
- PARAM, AEMESH
Bulk Data Entry Controls output of aerodynamic mesh used in aeroelastic analysis and the displacement field on the aerodynamic mesh.
- PARAM, AGGPCH
Bulk Data Entry To support output of the fluid-structure coupling matrix to the Punch (.pch) file as a matrix defined using DMIG data entry.
- PARAM, AKUSMOD
Bulk Data Entry Use external fluid-structure coupling matrix generated by AKUSMOD.
- PARAM, ALLFT
Bulk Data Entry This parameter is used to control the output from multiple failure theories to the H3D and .cstr files.
- PARAM, ALPHA1
Bulk Data Entry Adds Rayleigh damping to viscous damping for structural mesh.
- PARAM, ALPHA1FL
Bulk Data Entry Adds Rayleigh damping to viscous damping for fluid mesh.
- PARAM, ALPHA2
- PARAM, ALPHA2FL
- PARAM, AMLS
Bulk Data Entry Use external AMLS eigenvalue solver.
- PARAM, AMLSMAXR
Bulk Data Entry Used to determine singularities in the stiffness matrix for AMLS eigenvalue solver.
- PARAM, AMLSMEM
Bulk Data Entry Defines the amount of memory in Gigabytes to be used by the external AMLS eigenvalue solver.
- PARAM, AMLSNCPU
Bulk Data Entry Used to define the number of CPUs to be used by the external AMLS eigenvalue solver.
- PARAM, AMLSUCON
Bulk Data Entry Constrain unconnected grids for AMLS eigenvalue solver.
- PARAM, AMSE4CMS
Bulk Data Entry Controls the alternate method for the creation of CMS superelements using the AMSES eigensolver.
- PARAM, AMSE4EFM
Bulk Data Entry Controls the activation of the enforced motion static solution in the AMSES solver in conjunction with the normal modes calculation.
- PARAM, AMSESLM
Bulk Data Entry Indicates if the AMSES numerical mode for enforced motion based modal dynamic analysis with large mass method will be activated or not.
- PARAM, AMSFRMAT
Bulk Data Entry This parameter controls the method used for modal frequency response solution when frequency-dependent materials are present and AMSES is used as the eigensolver.
- PARAM, ASCOUP
Bulk Data Entry Generates the fluid-structure coupling (area) matrix for use in the solution.
- PARAM, AUNITS
Bulk Data Entry Converts accelerations specified in units of gravity on the TRIM Bulk Data Entry to units of distance per time squared.
- PARAM, AUTOMSET
Bulk Data Entry Automatically convert dependent degrees-of-freedom of rigid elements to independent degrees-of-freedom.
- PARAM, AUTOSPC
Bulk Data Entry Automatically constrain degrees-of-freedom with no stiffness.
- PARAM, AUTOSPRT
Bulk Data Entry Activate inertia relief and auto-support degree-of-freedom generation.
- PARAM, AXCYSYM
Bulk Data Entry Allows definition of a user-specified axis of symmetry, in cyclic symmetry analysis.
- PARAM, AXI2DTOR
Bulk Data Entry Converts 2D axisymmetric elements in the model to general axisymmetric elements.
- PARAM, BEAMALT
Bulk Data Entry Used to activate an alternate formulation for CBAR and CBEAM elements.
- PARAM, BUFFSIZE
Bulk Data Entry Defines the maximum size in 8 byte words of the records of data written to the .op2 file.
- PARAM, BUSHRLMT
Bulk Data Entry Issues a WARNING when the stiffness value for rotational components on the PBUSH entry exceeds the specified limit (BUSHRLMT).
- PARAM, BUSHSTIF
Bulk Data Entry Specifies a value to replace large stiffness values (>1.0E+07) input in field K of the PBUSH Bulk Data Entry.
- PARAM, BUSHTLMT
Bulk Data Entry Issues a WARNING when the stiffness value for translational components on the PBUSH entry exceeds the specified limit (BUSHTLMT).
- PARAM, CACONV
Bulk Data Entry Generates files which contain the generated internal CAFLUID elements, along with the CONV entries and CHBDYE elements.
- PARAM, CB2
Bulk Data Entry Scale factor for direct input damping matrices.
- PARAM, CDITER
Bulk Data Entry Controls the activation of MPC-based Fast Contact Analysis.
- PARAM, CDPCH
Bulk Data Entry Controls the printing of the final state of DMIG,CDSHUT for the constrained degrees of freedom at the gap interface to the PUNCH file for MPC-based Fast Contact Analysis.
- PARAM, CDPRT
Bulk Data Entry Controls the printing of violations during intermediate iterations in MPC-based Fast Contact Analysis to the .out file.
- PARAM, CHECKEL
Bulk Data Entry Activates element quality checking.
- PARAM, CHECKMAT
Bulk Data Entry Activates material property checking.
- PARAM, CHKELSET
Bulk Data Entry Specifies or excludes an element set from element quality check.
- PARAM, CHKGPDIR
Bulk Data Entry Activates gap direction alignment checking.
- PARAM, CHKM0
Bulk Data Entry OptiStruct calculates the ratio of
and prints a WARNING if the frequency interval may not be fine enough for accurate Fatigue Damage calculation.
- PARAM, CHKUCON
Bulk Data Entry Controls checking for unconnected parts when the AMSES eigensolver is used.
- PARAM, CK2
Bulk Data Entry Scale factor for direct input stiffness matrices.
- PARAM, CK3
Bulk Data Entry Specifies factors for the stiffness matrix produced by GENEL cards.
- PARAM, CM2
Bulk Data Entry Scale factor for direct input mass matrices.
- PARAM, CMSALOAD
Bulk Data Entry Controls the inclusion of mass contribution from the mass matrix stored in the PUNCH DMIG or the H3D DMIG files for the generation of RFORCE and Gravity Loads.
- PARAM, CMSDIRM
Bulk Data Entry Allows flexible body generation when directional masses are defined in the input file.
- PARAM, CMSGDMP
Bulk Data Entry Global damping for CMS superelement generation runs.
- PARAM, CMSOFST
Bulk Data Entry Consider shell offsets for flexbody generation.
- PARAM, CNST4FAT
Bulk Data Entry Defines the Corner Stress type for Fatigue analysis, if Corner Stress type is not requested, via the corresponding STRESS output request.
- PARAM, COEFFC
Bulk Data Entry Friction coefficient on curvatures for one-step stamping simulation.
- PARAM, COMP2SHL
Bulk Data Entry Results of homogenization of composite properties.
- PARAM, COMPSHST
Bulk Data Entry Controls the transverse shear stress calculation for composite shells, (PCOMP, PCOMPP, PCOMPG) and continuum shells (PCOMPLS).
- PARAM, CONTFEL
Bulk Data Entry Activates contact-friendly elements in Nonlinear Static/Transient Analysis (SMDISP/LGDISP).
- PARAM, CONVG
Bulk Data Entry Specifies output of a separate *_CONVG.fem file containing the internally generated entries coming from CONVG.
- PARAM, COUPMASS
Bulk Data Entry Use coupled mass matrix approach for eigenvalue/dynamic analysis.
- PARAM, CP2
Bulk Data Entry Scale factor for direct input load matrices.
- PARAM, CRTELEM
Bulk Data Entry Controls the printing of the “n” smallest element/nodal timesteps for Nonlinear Explicit Analysis.
- PARAM, CSTEVAL
Bulk Data Entry Use wall time based cost evaluation for Lanczos steps.
- PARAM, CSTOL
Bulk Data Entry Specifies how many decimal digits may be lost to cancellation in one operation during the eigensolution process.
- PARAM, CTSTF4PL
Bulk Data Entry Flag for tangential stiffness of closed gaps (closed contact elements) in nonlinear preloaded linear analysis.
- PARAM, CURVSHL2
Bulk Data Entry Activates a correction to strain and stress calculation for second order shell elements (CQUAD8, CTRIA6) that considers strong curvature of the shell (relative to shell thickness).
- PARAM, DDMNGRPS
Bulk Data Entry Identifies the number of groups into which the specified MPI processes (-np) are divided.
- PARAM, DFREQ
Bulk Data Entry Used to determine duplicate frequencies.
- PARAM, DIGIT
Bulk Data Entry Used to control the number of digits output to OPTI files.
- PARAM, DISIFMCK
Bulk Data Entry Skip indefinite mass matrix check.
- PARAM, DISJOINT
Bulk Data Entry Used to allow AMLS to handle disconnected parts. This can also be accomplished with PARAM, AMLSUCON.
- PARAM, DISPFIC
Bulk Data Entry Used to control the displacements output for the fictitious grids of CWELD, CGAP, CFAST and CSEAM elements.
- PARAM, DSZERO
Bulk Data Entry Sets a threshold (minimum absolute value) for the printing of Design Sensitivities.
- PARAM, DUPTOL
Bulk Data Entry Level of accuracy used in determining duplicate grids.
- PARAM, EDGESTR
Bulk Data Entry This parameter is a switch for the type of Grid Point Stress calculation for mid-edge nodes in second order elements.
- PARAM, EFFMAS
Bulk Data Entry Outputs modal participation factors and effective mass for normal modes analyses.
- PARAM, EHD
Bulk Data Entry Prints the inverse of the stiffness matrix created by static reduction to Fortran unit 3.
- PARAM, ELASRLMT
Bulk Data Entry Issues a WARNING when the stiffness value for rotational components on the CELAS2/CELAS4 or PELAS entry exceeds the specified limit (ELASRLMT).
- PARAM, ELASSTIF
Bulk Data Entry Specifies a value to replace large stiffness values (>1.0E+07) input in field K of the PELAS Bulk Data Entry.
- PARAM, ELASTLMT
Bulk Data Entry Issues a WARNING when the stiffness value for translational components on the CELAS2/CELAS4 or PELAS entry exceeds the specified limit (ELASTLMT).
- PARAM, ENFMETH
Bulk Data Entry Used to control the calculation of enforced displacement vectors in a Modal Frequency Response (MFREQ) analysis.
- PARAM, ENFMOTN
Bulk Data Entry Switch between relative and absolute displacement output in Modal Frequency Response Analysis with enforced motion.
- PARAM, EPZERO
Bulk Data Entry An upper bound for the stiffness ratio below which a degree of freedom will be regarded as an AUTOSPC candidate.
- PARAM, ERPAREA
Bulk Data Entry The ERP output.
- PARAM, ERPC
Bulk Data Entry The speed of sound used in the ERP calculation.
- PARAM, ERPREFDB
Bulk Data Entry Specifies the reference power value used to calculate Equivalent Radiated Power (ERP) in decibels (dB).
- PARAM, ERPRHO
Bulk Data Entry The fluid density used in ERP calculations.
- PARAM, ERPRLF
Bulk Data Entry The Radiation Loss Factor used in ERP calculation.
- PARAM, EXCEXB
Bulk Data Entry Controls the output of the AVL/EXCITE .exb file directly from OptiStruct.
- PARAM, EXCOP2
Bulk Data Entry This parameter controls the output of the AVL EXCITE _AVL.op2 file directly from OptiStruct.
- PARAM, EXPERTNL
Bulk Data Entry Activates a nonlinear expert system to aid in the convergence of Nonlinear (static and transient) Analysis.
- PARAM, EXPISOP
Bulk Data Entry This parameter controls the element integration scheme in Explicit Dynamic Analysis.
- PARAM, EXTOUT
Bulk Data Entry Controls the output of reduced matrices to external data files for use in subsequent analysis.
- PARAM, FASTCONT
Bulk Data Entry Activates the fast contact algorithm. This algorithm can only be used if the nonlinearity in the model comes from just contact.
- PARAM, FASTFR
Bulk Data Entry Controls the activation of a faster, alternative method (FASTFR) for Modal Frequency Response Analysis.
- PARAM, FASTINIT
Bulk Data Entry Controls the initialization of contact status in Fast Contact Analysis.
- PARAM, FCACSV
Bulk Data Entry This parameter controls the output of data in an Acoustic Complex Eigenvalue Analysis. If activated, the output is available in a <filename>.cmode.csv file.
- PARAM, FFRS
Bulk Data Entry Used to activate the external FastFRS (Fast Frequency Response Solver).
- PARAM, FFRSLFREQ
Bulk Data Entry Defines a frequency cut-off value in Hertz used to partition the structural system into low frequency and high frequency parts.
- PARAM, FFRSMEM
Bulk Data Entry Defines the amount of memory in Gigabytes to be used by the external FastFRS modal equation solver.
- PARAM, FFRSNCPU
Bulk Data Entry Defines the number of CPUs to be used by the external FastFRS solver.
- PARAM, FIXRBE3
Bulk Data Entry Used to automatically fix invalid RBE3’s.
- PARAM, FLEXH3D
Bulk Data Entry Generates flexh3d files for flexible bodies in an MBD analysis.
- PARAM, FLIPOK
Bulk Data Entry Allows tetrahedral elements to invert during shape optimization.
- PARAM, FLLWER
Bulk Data Entry Calculation of follower forces introduced by pressure loads and concentrated forces in large displacement nonlinear analysis.
- PARAM, FRIC
Bulk Data Entry Defines multiplier for K2PP reference.
- PARAM, FZERO
Bulk Data Entry Identifies the maximum frequency of a rigid body mode for the Lanczos eigensolver.
- PARAM, G
Bulk Data Entry Specifies the uniform structural damping coefficient for dynamic analyses.
- PARAM, GE4FRSTF
Bulk Data Entry Controls the contribution of material damping, in addition to the stiffness contribution in the element force calculation for frequency response analysis.
- PARAM, GE4TRSTF
Bulk Data Entry Controls the contribution from damping, in addition to the stiffness contribution in the element force calculation for Linear Transient Analysis.
- PARAM, GE_MOD
Bulk Data Entry Modifies specified GE values.
- PARAM, GFL
Bulk Data Entry Specifies the uniform fluid damping coefficient for dynamic analyses.
- PARAM, GLOBEXPT
Bulk Data Entry Applies to Global-Local Modeling. Expanding the interpolation patch results in a smoother solution near the cut surface.
- PARAM, GMAR
Bulk Data Entry Controls the accuracy of the external AMLS eigenvalue solution.
- PARAM, GMAR1
- PARAM, GPSLOC
Bulk Data Entry Controls where the grid point stresses are calculated for output to the .mnf file.
- PARAM, GRDPNT
Bulk Data Entry Obsolete Nastran parameter that will give information about the mass properties of the structure.
- PARAM, GRDPNTCM
Bulk Data Entry The CMASS1 and CMASS2 elements are included or excluded in the Grid Point Weight Generation output.
- PARAM, GRIDFORM
Bulk Data Entry Controls the output format of the .grid file.
- PARAM, GYRO1D
Bulk Data Entry Activates/deactivates the calculation of 1D Gyroscopic Matrix for 1D Rotors in Rotor dynamics.
- PARAM, GYROAVG
Bulk Data Entry Used to select the frequency response analysis formulation type for rotor dynamics analysis.
- PARAM, GYROTIMO
Bulk Data Entry Controls the inclusion or exclusion of shear effect in the beam gyroscopic matrix.
- PARAM, HASHASSM
Bulk Data Entry Enables hash-table based assembly.
- PARAM, HEX8ALT
Bulk Data Entry Controls an alternative formulation of 8-noded CHEXA element for linear analysis.
- PARAM, HFREQ
Bulk Data Entry Specifies the upper bound of the frequency range of interest for modal combination.
- PARAM, HFREQFL
Bulk Data Entry Excludes modes with frequencies greater than HFREQFL in Coupled Modal Frequency Response Analysis (Acoustic Analysis).
- PARAM, HGHCMPOK
Bulk Data Entry Used to turn on or off the check for negative and very large compliance values.
- PARAM, HOURGLS
Bulk Data Entry Controls the hourglass type.
- PARAM, IMPLOUT
Bulk Data Entry On-the-fly incremental results of nonlinear implicit (static and transient) analysis.
- PARAM, INREL
Bulk Data Entry Controls the calculation of inertia relief.
- PARAM, INRELBCK
Bulk Data Entry This parameter controls the handling of buckling analysis based under inertia relief analysis.
- PARAM, INRELOUT
Bulk Data Entry Controls the output of inertia relief-corrected applied loading in conjunction with OLOAD request.
- PARAM, INTRFACE
Bulk Data Entry Generates the .interface file to verify if proper connection has been established between the Fluid and Structure meshes at the interface.
- PARAM, IR4NLCON
Bulk Data Entry Inertia relief for nonlinear analysis.
- PARAM, ISTRSBAL
Bulk Data Entry Controls the application of initial stress over the nonlinear subcase.
- PARAM, ITAPE
Bulk Data Entry Writes the 'Tape Label' at the beginning of the OUTPUT2 results file.
- PARAM, K4CUTOFF
Bulk Data Entry Sets cut-off value if the low rank representation for the structural damping matrix is selected.
- PARAM, K4METH
Bulk Data Entry Specifies the value of PARAM,LOWRANK, which indicates the solution type for the faster Modal Frequency Response solution method invoked by PARAM,FASTFR and the FastFRS interface invoked by PARAM,FFRS.
- PARAM, KDAMP
Bulk Data Entry Enters viscous modal damping into the stiffness matrix as structural damping.
- PARAM, KGRGD
Bulk Data Entry Include contributions from rigid elements in the geometric stiffness matrix.
- PARAM, KISSSOFT
Bulk Data Entry Controls the creation of the condensed stiffness matrix in an ASCII file to be used by the KISSsoft program.
- PARAM, KSMNL4PL
Bulk Data Entry Control stiffness calculations in linear analysis that is preloaded with small displacement NLSTAT analysis.
- PARAM, KTPLAST
Bulk Data Entry Beneficial for problems involving a combination of plasticity, contact, and pretension.
- PARAM, LCLGRDST
Bulk Data Entry This parameter can be defined in the local model of a submodeling job, to output the mapping information of each local node to the global nodes, for all the local nodes in a set.
- PARAM, LFREQ
Bulk Data Entry Used to remove the Rigid Body Modes from the Modal Space.
- PARAM, LFREQFL
Bulk Data Entry Excludes modes with frequencies lower than LFREQFL in Coupled Modal Frequency Response Analysis (Acoustic Analysis).
- PARAM, LFREQH3D
Bulk Data Entry This parameter can be used to request only the modes (structural or coupled) that satisfy the lower bound of frequency, for H3D output.
- PARAM, LGDISP
Bulk Data Entry Activates Large Displacement Nonlinear Analysis.
- PARAM, LMSOUT
Bulk Data Entry Outputs the condensed Flex Body Modes, full Diagonal Mass Matrix, and modal stresses to the .op2 file.
- PARAM, LOWRANK
Bulk Data Entry This parameter is obsolete. Use PARAM,K4METH to control the value of LOWRANK.
- PARAM, LSNLEXP
Bulk Data Entry In the small displacement NLSTAT solution that has difficulties converging, the “expert system” will try, among other remedies, activation of Line Search.
- PARAM, MASSDMIG
Bulk Data Entry For static condensation with ASET of a static loadcase, the reduced stiffness matrix [k] and load vector {p} are created.
- PARAM, MATFREQ
Bulk Data Entry Turns off any frequency-dependent materials (MATF#) that are present in the model.
- PARAM, MAXDAMP
Bulk Data Entry Identifies the maximum number of residual vectors to be calculated.
- PARAM, MAXRATIO
Bulk Data Entry Defines the maximum allowed value of the ratio of terms on the diagonal of the stiffness matrix to the corresponding diagonal terms of the triangular factor matrix during decomposition.
- PARAM, MBDDAMP
Bulk Data Entry Specifies inclusion of the generalized damping matrix in the Flex H3D file.
- PARAM, MBDH3D
Bulk Data Entry Choose the type of the results output to the .h3d file for MBD analyses.
- PARAM, MBDREC
Bulk Data Entry Creates small and large flexible body files during Component Mode Synthesis (CMS).
- PARAM, MCHGRMV
Bulk Data Entry Controls the participation of elements removed by MODCHG in the analysis.
- PARAM, MDK4OPT
Bulk Data Entry Controls the internal calculation of material damping when different material damping values (GE on MATx) are specified for different regions in a model.
- PARAM, MDTRKFLT
Bulk Data Entry Perform mode tracking.
- PARAM, MEMTRIM
Bulk Data Entry Activates/deactivates the memory-trim feature when using AMLS eigensolver.
- PARAM, MFILTER
Bulk Data Entry Defines a threshold for the mode tracking matrix to check eigenvector correspondence.
- PARAM, MODETRAK
Bulk Data Entry Tracks mode numbers by comparing eigenvectors between iterations.
- PARAM, MVASPCON
Bulk Data Entry Controls the auto SPC of degrees of freedom with both mass and viscous damping.
- PARAM, MZEROHZ
Bulk Data Entry Controls frequency inclusion in moments calculation for random response fatigue analysis.
- PARAM, NBZRCSR
Bulk Data Entry Identifies whether the Number of Peaks or Number of Zero Crossings are used for NARROW band model in Random Response Fatigue Analysis.
- PARAM, NEGMASS
Bulk Data Entry Allows run to proceed with negative diagonal mass terms.
- PARAM, NEWCRD
Bulk Data Entry Used to control switching between alternative and traditional constraint reduction methods.
- PARAM, NLFAT
Bulk Data Entry Forces OptiStruct to run models in which fatigue solutions reference small displacement nonlinear analysis (NLSTAT) subcases.
- PARAM, NLINISOL
Bulk Data Entry The optimization process involving nonlinear analysis, in the subsequent optimization iteration the solution of the nonlinear problem.
- PARAM, NLMON
Bulk Data Entry This parameter activates Nonlinear Results Monitoring. Currently, only displacement results monitoring is available.
- PARAM, NOUTCYC
Bulk Data Entry Frequency for output control. OptiStruct will write results to the .out file in every NOUTCYC step.
- PARAM, NPRBAR
Bulk Data Entry Controls the number of the output INFORMATION #741 for RBAR element.
- PARAM, NPRBE2
Bulk Data Entry Controls the number of the output INFORMATION #741 for RBE2 element.
- PARAM, NPRGDE
Bulk Data Entry Controls the number of the output INFORMATION #742.
- PARAM, NUMEG
Bulk Data Entry Specifies the anticipated number of modes to be calculated in order to estimate disk space usage.
- PARAM, ODS
Bulk Data Entry An Operating Deformed Shape (ODS) run requires the output for all the elements or all the grids for limited loading frequencies of interest.
- PARAM, OGEOM
Bulk Data Entry Outputs model data to the OUTPUT2 results file.
- PARAM, OMACHPR
Bulk Data Entry Selects newer version of certain OUTPUT2 datablocks.
- PARAM, OMID
Bulk Data Entry Outputs stress and strain results for shell and membrane elements with reference to the material coordinate system.
- PARAM, OP2GM34
Bulk Data Entry Controls the output of GEOM3 and GEOM4 data blocks to the .op2 file.
- PARAM, OPSTS
Bulk Data Entry Used to define how the stress and strain of plane stress elements (CQPSTS and CTPSTS) are output to H3D.
- PARAM, OPTI
Bulk Data Entry This parameter can be used to activate the new OPTI format, which is enhanced with labels for improved readability.
- PARAM, ORIGK4
Bulk Data Entry The value of PARAM,ORIGK4 is used to replace the GE damping field on any material Bulk Data Entry referenced by superelements.
- PARAM, PBTFCAP
Bulk Data Entry This parameter limits the applicability of PARAM,PBUSHTF properties.
- PARAM, PBUSHT
Bulk Data Entry Used to turn ON/OFF the usage of all PBUSHT Bulk Data Entries in the model.
- PARAM, PBUSHTF
Bulk Data Entry Specifies the reference frequency value for scaling factor lookup to update the nominal PBUSH Stiffness (K) values.
- PARAM, PEACTDMG
Bulk Data Entry Controls the output of the .eactdmg file for Pseudo Damage method in fatigue analysis.
- PARAM, PELAST
Bulk Data Entry Used to turn ON/OFF the usage of all PELAST Bulk Data Entries in the model.
- PARAM, PENT2ALT
Bulk Data Entry Controls an alternative formulation of 15-noded CPENTA element for linear analysis.
- PARAM, PLIGEXT
Bulk Data Entry Prints the applied load vector in DMIG form to the .pligext file.
- PARAM, PNLSIZ
Bulk Data Entry Increases the starting size of panel to the specified value.
- PARAM, POST
Bulk Data Entry Generates an OUTPUT2 results file.
- PARAM, POSTEXT
Bulk Data Entry Outputs the modal complex stiffness matrix and modal viscous damping matrix to the OUTPUT2 results file.
- PARAM, PREFDB
Bulk Data Entry Used to activate dB and dB(A) output in H3D and PUNCH file formats for Fluid-Structure Coupled Frequency Response Analysis.
- PARAM, PRESUBNL
Bulk Data Entry Forces OptiStruct to run models in which Linear Buckling Analysis or Preloaded Analysis is defined, in conjunction with nonlinear materials (MATS1, MATHE, or MGASK) or Large Displacement Nonlinear Analysis.
- PARAM, PRGPST
Bulk Data Entry Outputs AUTOSPC information to the .out file.
- PARAM, PRINFACC
Bulk Data Entry Controls the output of inertial relief rigid body forces and accelerations.
- PARAM, PRTDES
Bulk Data Entry Controls the printing of Design Variables and Design Entities to the .out file.
- PARAM, PRTNORM
Bulk Data Entry Defines the maximum number of contributions printed for each norm response under the norm response itself in the .out file for an Optimization run.
- PARAM, PRTRET
Bulk Data Entry Controls the printing of Retained Response information to the .out file.
- PARAM, PRTMGG
Bulk Data Entry Defines the Mass Matrix.
- PARAM, PSDPRINC
Bulk Data Entry This parameter controls the output of PSD/RMS Absolute Maximum Principal Stress and PSD/RMS Absolute Maximum Principal Strain for Random Response Analysis.
- PARAM, RBD2ELEM
Bulk Data Entry Used to control how RBODY entries in the model are internally processed.
- PARAM, RBE2FREE
Bulk Data Entry Used to convert ERROR 725 into WARNING 825 when singular RBE2 elements are present in the model.
- PARAM, RBE3COL
Bulk Data Entry This parameter controls the handling of RBE3 elements.
- PARAM, RBE3FREE
Bulk Data Entry Used to convert ERROR 772 into WARNING 824 when free spiders on RBE3 elements are present in the model. These free spiders may contain singular degrees-of-freedom.
- PARAM, RBMEIG
Bulk Data Entry Defines the cut-off eigenvalue for determining rigid body modes calculated by AMLS.
- PARAM, REANAL
Bulk Data Entry Reanalyze the final iteration of a topology optimization without penalization.
- PARAM, RECOVER
Bulk Data Entry Allows you to request full-structure global mode shape output instead of the modes of the condensed system generated during Component Mode Synthesis (CMS).
- PARAM, REFPNT
Bulk Data Entry The reference point for Inertia Relief of the model.
- PARAM, RENUMOK
Bulk Data Entry Allows you to correctly renumber the reversed (but acceptable) sequence of element grids without having to run (import and re-export) the model through HyperMesh.
- PARAM, RFIOUT
Bulk Data Entry Controls the output of modal super element for use in the RecurDyn multibody dynamics software from FunctionBay.
- PARAM, RHOCP
Bulk Data Entry The scale factor used to calculate ERP in decibels (dB).
- PARAM, RICARDO
Bulk Data Entry Controls the creation of the condensed flex body modes and full diagonal mass matrix to the .op2 file to be used by VALDYN from Ricardo Software.
- PARAM, ROMAX
Bulk Data Entry Controls the creation of the condensed stiffness, mass, and displacement recovery matrices for use with Romax Technology.
- PARAM, RSPLICOR
Bulk Data Entry RSPLINE end rotation correction.
- PARAM, S2K
Bulk Data Entry Controls the creation of analysis results to be used by the STRENGTH2000 program to the .op2 file.
- PARAM, SBTOLRTR
Bulk Data Entry Used to modify the tolerance value for symmetric beams when they are used for rotor modeling.
- PARAM, SEP1XOVR
Bulk Data Entry The old and new location of moved shell grid points are printed if SEP1XOVR = 16.
- PARAM, SEPLOT
Bulk Data Entry Outputs display model to .seplot file, from a CMS run.
- PARAM, SETINC
Bulk Data Entry Generates a SET of elements for each include file specified in the model.
- PARAM, SHEARALT
Bulk Data Entry Activates an alternative formulation for CSHEAR elements.
- PARAM, SHELLLG
Bulk Data Entry Activate an alternative 1st order Nonlinear Large Displacement shell element (CQUAD4 and CTRIA3 elements).
- PARAM, SHELLTI
Bulk Data Entry Identifies the handling of nodal shell thicknesses defined on the shell element entries.
- PARAM, SHELOS11
Bulk Data Entry Allows you to revert to the first order shell element formulation (for CQUAD4 and CTRIA3) used in version 11.0.240 and earlier.
- PARAM, SHL2MEM
Bulk Data Entry A shell property (defined by the PSHELL Bulk Data Entry) is automatically converted into a membrane property if the membrane thickness (field T) of the PSHELL Bulk Data Entry is less than the value specified using PARAM, SHL2MEM.
- PARAM, SHPBCKOR
Bulk Data Entry Defines the type and order of approximation used in plate bending geometric stiffness for linear shell elements (CQUAD4, CTRIA3).
- PARAM, SIGMA
Bulk Data Entry The Stefan-Boltzmann constant used in Radiation Heat Transfer calculations.
- PARAM, SIMDRIVE
Bulk Data Entry Controls the output of the <filename>._simdrive.h3d file directly from OptiStruct.
- PARAM, SIMPACK
Bulk Data Entry Requests generation of the SIMPACK .fbi file containing flexible body information for SIMPACK analysis.
- PARAM, SIMVER
Bulk Data Entry This parameter can be used to select the SIMPACK version for multibody dynamics analysis.
- PARAM, SORTCON
Bulk Data Entry Controls the output of violated constraints to the .out file from an optimization.
- PARAM, SPLC
Bulk Data Entry Specifies the speed of sound used in the wave number and the complex particle velocity vector calculations.
- PARAM, SPLFAC
Bulk Data Entry Specifies the scale factor (q) used to calculate the Sound Pressure Level in Radiated Sound Analysis.
- PARAM, SPLREFDB
Bulk Data Entry Specifies the reference sound pressure value used to calculate the Sound Pressure Level (SPL) in decibels (dB).
- PARAM, SPLRHO
Bulk Data Entry Specifies the density of the acoustic medium in the calculation of the complex acoustic sound pressure and the complex particle velocity vector.
- PARAM, SRCOMPS
Bulk Data Entry Outputs the strength ratios for composite elements that have failure indices requested.
- PARAM, SS2GCR
- PARAM, STRTHR
Bulk Data Entry Used to specify the von Mises stress threshold above which the stress results are output for a model.
- PARAM, SUBRESVC
Bulk Data Entry Used to control whether residual vector generation is subcase-dependent when the AMSES eigensolver is used.
- PARAM, TABS
Bulk Data Entry Converts units of the temperature input (Fahrenheit or Celsius) to the absolute temperature (Degrees Kelvin).
- PARAM, TCLTINIT
Bulk Data Entry Defines the lower threshold value used for the HyperMesh command files *.HM.comp.tcl and *.HM.ent.tcl.
- PARAM, TCLTSTEP
Bulk Data Entry Defines the step or interval value used for the HyperMesh command files *.HM.comp.tcl and *.HM.ent.tcl.
- PARAM, THCNTPEN
Bulk Data Entry Controls the penalty factor used in thermal contact analysis.
- PARAM, THMLSTN
Bulk Data Entry Select the thermal strain formula.
- PARAM, TOLRSC
Bulk Data Entry Connecting grid points of the shell element are moved onto the solid face.
- PARAM, TRAKMETH
Bulk Data Entry Used to select the criterion employed for mode tracking.
- PARAM, TRAKMTX
Bulk Data Entry Controls output of the mode tracking matrix during optimization.
- PARAM, TPS
Bulk Data Entry Activates fast transient response analysis (only shell stress results output).
- PARAM, UCORD
Bulk Data Entry Specifies the coordinate system in which the mass moment of inertia is output. It also can be used to control the point about which the mass moment of inertia is calculated.
- PARAM, UFREQH3D
Bulk Data Entry This parameter can be used to request only the modes (structural or coupled) that satisfy the upper bound of frequency, for H3D output.
- PARAM, UFREQPCH
Bulk Data Entry This parameter can be used to request only the modes (structural or coupled) that satisfy the upper bound of frequency, for PCH output.
- PARAM, UHT
Bulk Data Entry Outputs the UHT data block.
- PARAM, UNSM2SM
Bulk Data Entry This parameter is used to convert an unsymmetrical K2PP or M2PP matrix to a symmetrical matrix.
- PARAM, UNSYMSLV
Bulk Data Entry Controls the inclusion or exclusion of non-symmetric terms in the tangent stiffness matrix due to friction in frictional contact problems.
- PARAM, VAPMTV
Bulk Data Entry This parameter is used to define the vacuum permittivity for piezoelectric materials.
- PARAM, VISC2MAT
Bulk Data Entry Used to convert viscous damping matrix to material damping matrix.
- PARAM, VMMASS
Bulk Data Entry Used with MFLUID and PARAM,GRDPNT.
- PARAM, VMOPT
Bulk Data Entry Allows you to prevent the inclusion of the Virtual Mass Matrix in the Regular Mass Matrix for Modal Dynamic Subcases. In such cases, the virtual mass is added after the eigen solution and modes are modified based on the virtual mass matrix.
- PARAM, VREF
Bulk Data Entry Used in aeroelastic flutter analysis to specify a factor to divide the velocities.
- PARAM, W3
Bulk Data Entry Converts structural damping to equivalent viscous damping for transient analysis.
- PARAM, W4
- PARAM, WRH
Bulk Data Entry Used to include or exclude rotor material hybrid damping in rotor dynamics analysis.
- PARAM, WR3
Bulk Data Entry Used to include or exclude rotor structural damping in rotor dynamics analysis.
- PARAM, WR4
Bulk Data Entry Used to include or exclude rotor material damping in rotor dynamics analysis.
- PARAM, WTMASS
Bulk Data Entry Converts weights to masses using this multiplier.
- PARAM, XB
Bulk Data Entry This parameter can be used to print nodal coordinate information in the local coordinate system in an additional field/column in the .h5 file.
- PARAM, XPOST
Bulk Data Entry Used to create the .elfo (element forces), .elsh (element shear), and .endl (end loads) output files.
- PARAM, ZAERO
Bulk Data Entry Outputs an ASCII file (.zaero) containing the normal modes data for the requested grids. This file can be used to import into ZAERO software, for further aeroelastic analysis.
