2026
This manual provides a detailed list and usage information regarding input entries, output entries, and parameters available in OptiStruct.
View new features for OptiStruct 2026.
OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
Discover OptiStruct functionality with interactive tutorials.
This manual provides detailed information regarding the features, functionality, and simulation methods available in OptiStruct.
OptiStruct will continue to support the old input format from version 3.5. The new optimization capabilities will not be available if the old format is used for the set up of the optimization problem, that is, if matfrac, mini, maxi, ubcon or lbcon are present. This section is intended to be used for the purpose of debugging or re-running older decks.
Setting up an optimization was simpler in OptiStruct 3.5, but it was also very limited. Starting with OptiStruct 5.0, a lot more flexibility has been added to the way objectives and constraints are set up, but the problem setup is more complex.
A list of previously supported input keywords.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides you with examples of the real-world applications and capabilities of OptiStruct.
This manual presents solved verification models including NAFEMS problems.
This section provides quick responses to typical and frequently asked questions regarding OptiStruct.
