Deck Setup in OptiStruct 5.0 and higher with OptiStruct 3.5 Objectives and Constraints
Setting up an optimization was simpler in OptiStruct 3.5, but it was also very limited. Starting with OptiStruct 5.0, a lot more flexibility has been added to the way objectives and constraints are set up, but the problem setup is more complex.
Although versions of OptiStruct (including and beyond 5.0) will execute OptiStruct 3.5 decks flawlessly, you are urged to create decks using the new optimization format. This section demonstrates how objectives and constraints in OptiStruct 3.5 (such as comp, freq, wcomp, wfreq, and comb) can be set up in OptiStruct 5.0 and higher.
The new optimization capabilities of OptiStruct 5.0 and higher will not be available if the old format is used for the setup of the optimization problem (if matfrac, mini, maxi, ubcon, or lbcon are present in the setup).
Minimize Compliance for Constrained Mass Fraction
In OptiStruct 3.5, two cards were used to do this kind of optimization: mini, comp and ubcon, 0.3, volume.
DESGLB = 101
SUBCASE 1
LOAD = 2
SPC = 1
DESOBJ(MIN) = 1
BEGIN BULK
DRESP1, 1, comp, COMP
DRESP1, 100, massf, MASSFRAC
DCONSTR, 101, 100, , 0.300
$Minimize Mass for Constrained Displacement
DESOBJ(MIN) = 1
SUBCASE 1
LOAD = 2
SPC = 1
DESSUB = 101
BEGIN BULK
DRESP1, 1, weight, MASS
DRESP1, 100, disp, DISP, , , 7, , 1202
DCONSTR, 101, 100, , 1.4e-6
$Minimize Weighted Compliance for Constrained Mass
DESOBJ = 50
DESGLB = 101
SUBCASE 1
LOAD = 2
SPC = 1
WEIGHT = 2.0
SUBCASE 2
LOAD = 3
SPC = 1
WEIGHT = 1.0
BEGIN BULK
DRESP1, 50, wcomp, WCOMP
DRESP1, 100, weight, MASS
DCONSTR, 101, 100, , 1.560
$Maximize Frequency for Constrained Volume
DESGLB = 101
SUBCASE 1
METHOD = 2
SPC = 1
DESOBJ(MAX) = 1
BEGIN BULK
DRESP1, 1, freq1, FREQ, , , 1
DRESP1, 100, vol, VOLUME
DCONSTR, 101, 100, , 20000.0
$Maximize Weighted Frequencies for Constrained Volume
DESGLB = 101
DESOBJ(MIN) = 11
SUBCASE 1
METHOD = 2
SPC = 1
MODEWEIGHT, 1, 1.0
MODEWEIGHT, 2, 1.0
BEGIN BULK
DRESP1, 11, wfreq, WFREQ
$Minimize Combined Compliance and Frequencies for Constrained Volume Fraction
In OptiStruct 3.5, the combined reciprocal frequency and compliance response (comb) required a normalization factor in order to properly add frequency values and compliance. The equivalent setup for OptiStruct 5.0 and higher is shown below.
DESOBJ(MIN) = 50
DESGLB = 101
NORM = 1000.0
SUBCASE 1
LOAD = 2
SPC = 1
WEIGHT = 1.0
SUBCASE 2
LOAD = 3
SPC = 1
WEIGHT = 1.0
SUBCASE 3
METHOD = 10
SPC = 1
MODEWEIGHT, 1, 1.5
MODEWEIGHT, 2, 1.0
BEGIN BULK
DRESP1, 50, comp, COMB
DRESP1, 100, volf, VOLFRAC
