CMBEAMM
Bulk Data Entry Defines a beam element for multibody dynamic solution sequence without reference to a property entry based on markers.
CMBEAMM EID MID M1 M2 L
A I1 I2 J K1 K2
CMBEAMM 1 2 123 125 0.0 0.0 1.0 5.0
100.0 833.3 833.3 1485.3
EID Unique element identification number.
(Integer > 0)
MID Material identification number.
(Integer > 0)
M1 Marker identification number.
(Integer > 0)
M2 Marker identification number.
(Integer > 0)
L Undeformed length along the X-axis of the beam.
(Real)
A Area of the beam cross-section.
(Real)
I1 Area moment inertia in plane 1 about the neutral axis.
No default (Real > 0.0)
I2 Area moment inertia in plane 2 about the neutral axis.
J Torsional constant.
(Real > 0.0)
K1, K2 Area factor for shear.
Default = 0.0 (Real)
  1. The X-axis of the markers M1 and M2 should always be along the axis of the beam.
  2. The moments of inertia are defined as:
    | 1 = / z z = y 2 d A | 2 = / y y = Z 2 dA
    The beam coordinates must be aligned with the principal axes of the cross-section.
  3. The transverse shear stiffness in planes 1 and 2 are (K1)AG and (K2)AG, respectively. If a value of 0.0 is used for K1 and K2, the transverse shear flexibilities are set to 0.0 (K1 and K2 are interpreted as infinite).
  4. This card is represented as a bar element in HyperMesh.
