TEMP
Bulk Data Entry Defines temperature at grid points or a SET of grid points for determination of thermal loading and stress recovery.
| TEMP | SID | G/ GSETID |
T/ASSIGN_ID | G | T | G | T | ||
| GSET | ASSIGN |
| TEMP | 3 | 94 | 316.2 | 49 | 219.8 |
Example with ASSIGN
| TEMP | 3 | 94 | 100 | ||||||
| + | GSET | ASSIGN |
| SID | LOAD
set identification (Integer > 0) |
| G/GSETID | This field represents a
grid point identification number, or if the GSET
continuation line is specified, an identification number of a
SET of grid points. (Integer > 0) |
| T/ASSIGN_ID | Temperature/if
ASSIGN is specified, ID of an
ASSIGN,H3DRES entry. (Real for Temperature, Integer if ASSIGN is specified) |
| GSET | Flag which indicates that the G/GSETID field is identified as a SET of grid points, at which the temperatures are applied. | |
| ASSIGN | Flag indicating that the T field is identified as ASSIGN_ID, which is the ID of an ASSIGN entry. If the field is identified as ASSIGN_ID, the field should be defined as an integer. |
- Temperature sets may be selected for use in a subcase by the TEMPERATURE(LOAD) or TEMPERATURE(BOTH) Subcase Information Entry. They can also be selected by the EXCITEID field of a TLOAD# entry or selected on the IC Subcase Information Entry. They can also be combined with other TEMP, TEMPD or TEMPSEC Bulk Data Entries on a TEMPADD Bulk Data Entry. For more information, refer to the TEMPERATURE Subcase Information Entry.
- From one to three grid point temperatures may be defined on a single entry. If the GSET continuation line is present, then the referenced SET can consist of any number of grid points.
- This card is represented as a temperature load in HyperMesh.
- The ASSIGN keyword
can be used to assign multiple temperatures to multiple components/parts. Each
component can have a SET containing all grid points related to that component
and the temperatures from the external H3D file can be assigned to these grid
points. Any adjoining component sharing boundary nodes can be assigned another
set of temperatures from a new external H3D file. The same boundary nodes are
assigned new temperatures from the last ASSIGN,H3DRES file in
the TEMPADD list. Below is an example of how
TEMPADD is used to add all the temperatures from various
ASSIGN,H3DRES
files:
ASSIGN,H3DRES,150,heat_tran_h3d_gen.h3d SUBCASE 1 LABEL HEAT_transient ANALYSIS HEAT TSTEP = 1 IC = 100 BEGIN BULK TSTEP,1,10,10.0,1 TEMP,10,3,30.0 +,GSET TEMP,20,4,150, +,GSET,ASSIGN TEMPADD,100,1.0,1.0,10,1.0,20
