PBUSH
Bulk Data Entry Defines the nominal property values for a generalized spring-damper-mass structural element.
| PBUSH | PID | K | K1 | K2 | K3 | K4 | K5 | K6 | |
| KMAG | KMAG1 | KMAG3 | KMAG4 | KMAG5 | KMAG6 | ||||
| B | B1 | B2 | B3 | B4 | B5 | B6 | |||
| GE | GE1 | GE2 | GE3 | GE4 | GE5 | GE6 | |||
| ANGLE | ANGLE1 | ANGLE2 | ANGLE3 | ANGLE4 | ANGLE5 | ANGLE6 | |||
| M | M1 | M2 | M3 | M4 | M5 | M6 | |||
| ESDAMP | ESD |
| + | SELECT | SELECTID | |||||||
| + | K | K1 | K2 | K3 | K4 | K5 | K6 | ||
| + | etc. |
Example 1
| PBUSH | 35 | K | 4.35 | 2.4 | RIGID | 3.1 | |||
| GE | 0.02 |
Example 2
| PBUSH | 35 | B | 4.35 | ||||||
| M | 1.2 | 7.1 |
Example 3
| PBUSH | 35 | KMAG | 3944.0 | ||||||
| ANGLE | 15.0 |
Example 4: Subcase-dependent Property Selection
| GE | 0.02 | ||||||||
| + | SELECT | 33 | |||||||
| K | 3.2 | 1.2 | RIGID | 5.0 | |||||
| + | GE | 0.015 | |||||||
| + | SELECT | 34 | |||||||
| + | K | 2.0 | 2.2 | RIGID | 3.5 | ||||
| + | GE | 0.015 |
| PID | Unique property identification.
No default (Integer > 0 or <String>) |
| K | Flag indicating that the next 1 to 6
fields are stiffness values. No default (Character) |
| Ki | Nominal stiffness values in directions 1
through 6. 4
6
8 If RIGID is defined, a very high relative stiffness is selected for that degree-of-freedom simulating a rigid connection. The rigid element formulation can be controlled using SYSSETTING(PBUSHFOR). Default = 0.0 (Real or RIGID) |
| KMAG | Flag indicating that the next 1 to 6
fields are stiffness magnitude (K*) values. 4 No default (Character) |
| KMAGi | Nominal stiffness magnitude (K*) values
in directions 1 through 6. 4
6
8
9 Default = 0.0 (Real) |
| B | Flag indicating that the next 1 to 6
fields are force-per-velocity damping. No default (Character) |
| Bi | Nominal damping coefficients in
directions 1 through 6 in units of force per unit velocity. Default = 0.0 (Real) |
| GE | Flag indicating that the next 1 to 6
fields are the structural damping constants. No default (Character) |
| GEi | Nominal structural damping constants in
directions 1 through 6. GEi is ignored in transient analysis, if PARAM, W4 is not specified. 4 6 Default = 0.0 (Real) |
| M | Flag indicating that the next 1 to 6 fields are directional masses. | |
| Mi | Nominal mass values in directions 1
through 6. In case of implicit analysis: 10
In case of explicit analysis:
| ANGLE | Flag indicating that the next 1 to 6
fields are Loss angles defined in degrees. 9 No default (Character) |
| ANGLEi | Nominal angle values in directions 1 through 6 in degrees. 4 6 8 9 | |
| SELECT | Indicates that the subcase-dependent material definitions are to follow. | |
| SELECTID | Identification number of the
SELECT subcase-dependent definition. This ID is used as
reference for SELECT Subcase Information Entry. No default (Integer > 0) |
| ESDAMP | Flag indicating that the next field is strain energy proportional damping. 12 | |
| ESD | Damping coefficient used for strain
energy proportional damping. 12 Default = blank (Real ≥ 0.0) |
- All generalized spring-damper-mass property entries must have unique ID numbers.
- String based labels allow for easier visual identification of properties, including when being referenced by other cards. (For example, the PID field of elements). For more details, refer to String Label Based Input File in the Bulk Data Input File.
- The K, B, GE, and M lines may be specified in any order.
- Ki, KMAGiBi,
GEi, ANGLEi or Mi may be made
frequency dependent for both direct and modal frequency response by use of the PBUSHT entry.
The nominal values are used for all analysis types except frequency response. For modal frequency response, the normal modes are computed using the nominal stiffness and mass values. The frequency-dependent values are used at every excitation frequency.
- To obtain the damping coefficient GE, multiply the critical damping ratio by 2.0.
- For backward compatibility with Nastran, if ONLY GE1 is specified on a PBUSH entry and GEi, i = 2 to 6 are blank on that PBUSH entry, then a single structural damping is assumed and applied to all Ki of that PBUSH. If a PBUSH entry has a GEi, i = 2 to 6 specified (even as 0.0), then the GEi fields are considered variable for that PBUSH entry.
- The nominal property values specified on the PBUSH entry are used on the corresponding fields (that are blank) of the PBUSHT entry.
- Rotational stiffness values are input based on rotations defined in Radians.
- If PBUSH has
KMAG and ANGLE, the calculation for stiffness
(K) and damping (GE) are: Where,
- Magnitude of the stiffness
- Loss angle
KMAG and ANGLE types are alternative types to K and GE. Specifying KMAG and ANGLE along with K and/or GE will generate an OptiStruct error.
- The contribution of Mi fields to gravity and/or centrifugal loading are not included in case of implicit analysis.
- This card is represented as a property in HyperMesh.
- The ESDAMP line can be used to define the damping for strain energy proportional damping calculation. The output of strain energy proportional damping can be requested by OUTPUT, ESDAMP. If the ESD value is not defined, the element is not included in the calculation of the strain energy proportional damping.
