RSPEC
Bulk Data Entry Specifies directional combination method, modal combination method, excitation direction(s), response spectra and scale factors for Response Spectrum Analysis.
| RSPEC | RID | DCOMB | MCOMB | CLOSE | MMASS | RIGRESP | |||
| DTISPEC1 | SCALE1 | X11 | X12 | X13 | ZPA1 | FA1 | FB1 | ||
| DTISPEC2 | SCALE2 | X21 | X22 | X23 | ZPA2 | FA2 | FB2 | ||
| DTISPEC3 | SCALE3 | X31 | X32 | X33 | ZPA3 | FA2 | FB2 |
Example 1
| RSPEC | 35 | ALG | SRSS | 1.0 | |||||
| 7 | 1.3 | 0.5 | 0.5 | -1. |
Example 2
| RSPEC | 35 | SRSS | CQC | 0.0 | |||||
| 7 | 1.3 | 0.5 | 0.5 | -1. | |||||
| 4 | 2.0 | -2 | -0.0 | -1. | |||||
| 2 | 17. | 0.5 | -2.5 | -1. |
| RID | RSPEC
identification number. Must be unique. No default (Integer > 0) |
| DCOMB | Directional combination
method.
| MCOMB | Modal combination
method.
| CLOSE | Modal frequency closeness
parameter. 2 Default = 1.0 (Real ≥ 1.0) |
| MMASS | Keyword indicating missing
mass response is used. Default = blank |
| RIGRESP | Keyword specifying which
rigid response method is applied.
Default = blank |
| DTISPECi | Response spectrum
reference. Identification number of the DTI,SPECSEL entry. No default (Integer > 0) |
| SCALEi | Scale factor for
excitation. No default (Real <> 0.0) |
| Xij | Components of a vector representing ground excitation i, j = 1..3 | |
| ZPAi | Zero Period Acceleration
value. 4 No default (Real ≥ 0.0) |
| FAi, FBi | Frequency limits
indicating a pure periodic response or a pure rigid response. 4 No default (Real ≥ 0.0, FBi ≥ FAi) |
- DTISPEC2/SCALE2/X21/X22/X23 and DTISPEC3/SCALE3/X31/X32/X33 are optional ground excitations for multi-directional excitation. The directions of excitation have to be orthogonal to each other and will be reported as error otherwise.
- When MCOMB =
SRSS or NRL, natural frequencies that are
close will be summed by the ABS method. The close frequencies
are determined using the inequality.
Where, and are successive natural frequencies.
Then, they are combined with other modal contributions in accordance with the specified MCOMB option. Since natural frequencies are in ascending order, CLOSE values should be greater than or equal to 1.0.
- Response spectra values are defined as a table of frequencies in the X axis and the response spectra in the Y axis in a TABLED1 entry referenced by the DTI,SPECSEL entry. For any modes extracted during the response spectrum analysis that lie within or outside the range of the frequencies defined by the TABLED1 entry, linear interpolation or extrapolation is carried out to determine the corresponding spectral values associated with such modes.
- ZPAi must be defined
for missing mass response or rigid response with Lindley-Yow Method. Missing
mass response can be used together with both rigid response methods.
When RIGRESP option is active, the response is divided into periodic part and rigid part in modal combinations. A variable α is introduced as the ratio of the rigid part to the modal response of mode i, hence providing an estimate of the proportion of rigid part of the response.
Rigid part:
Periodic part:
Gupta method calculates α based on the frequency. When the frequency is less than FA, it is pure periodic response, so α = 0; When the frequency is greater than FB, it is pure rigid response, so α = 1; When the frequency is between FA and FB, a value [0,1] is adopted for α in the transition range.
Lindley-Yow method calculates α based on the acceleration response spectrum value. When the spectrum value is equal to ZPA, it is pure rigid response, so α = 1; When the spectrum value is less than ZPA it is pure periodic response, so α = 0; When the spectrum value is greater than ZPA, a value [0,1] is adopted for α in the transition range. It is optional to define FA in Lindley-Yow method, and α is 0 as long as the frequency is less than FA.ZPA FA FB MMASS Required GUPTA Required Required LINDLEY Required Optional - Refer to Response Spectrum Analysis in the User Guide for more details.
