Bulk Data Entry Defines properties for CAERO1 panels. This is used for Vortex Lattice
Method (VLM) and Doublet Lattice Method (DLM) in subsonic aeroelastic analysis.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
PAERO1 |
PID |
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
PAERO1 |
3 |
Field |
Contents |
SI Unit Example |
PID |
Property identification number. This is to be referenced by a
CAERO1 Bulk Data Entry. No default
(Integer > 0) |
- For the current release of
OptiStruct, only the PID
field is supported for the PAERO1 entry. For any
CAERO1 Bulk Data Entry, a PAERO1
reference should be provided and this PAERO1 entry can be
left blank.
