MAT2EC
Bulk Data Entry Defines the electrical material properties for anisotropic materials in electrical analysis.
MAT2EC | MID | RHOXX | RHOYY | RHOZZ | |||||
JHFRAC |
MAT2EC | 2 | .300 | 100 | 200 | |||||
2e5 |
MID | Unique material
RHOij | Electrical resistivity
along each direction. No default (Real > 0.0) |
JHFRAC | Fraction of Joule losses
over total power generated in the material. 3
- The material identification number may be shared with structural material property definitions (MAT1, MAT2, MAT8, MAT9, or MGASK) or thermal material property definitions (MAT4, MAT5), but must be unique with respect to other electrical material property definitions (MAT1EC or MAT2EC).
- The electrical conductivity matrix has the following
form:
- JHFRAC controls the percentage of power transferred to Joule heating losses. By default, all power generated by the material is transferred as Joule heating.
- This card is represented as a material in HyperMesh.
