DVLREL1
Bulk Data Entry Linearly relates a design variable to an analysis model loading.
| DVLREL1 | ID | TYPE | SID | LNAME | C0 | ||||
| ATT1 | ATT2 | ||||||||
| DVID1 | COEF1 | DVID2 | COEF2 | etc. |
To relate the Force value on grid 259 to Design Variable 5.
| DVLREL1 | 88 | FORCE | 1 | F | 0.0 | ||||
| 259 | 1 | ||||||||
| 5 | 1 | ||||||||
| DESVAR | 5 | 5.00 | 1.50 | 9.90 |
| ID | Relationship
identification number. ID must be unique with respect to other
DVLREL1 cards. No default (Integer > 0) |
| TYPE | Loading type.
No default |
| SID | Identification number of a
FORCE or MOMENT Bulk Data
Entry. This selection depends on the value of the
TYPE field. No default (Integer > 0) |
| LNAME | Load identifier.
No default |
| C0 | Constant in the design
variable and load relationship equation. Default = 0.0 (Real) |
| ATT1 | Identifies the grid point
at which the designed load is applied. No default (Integer > 0) |
| ATT2 | Identifies the coordinate
system for the designed load reference. No default (Integer > 0) |
| DVIDi | DESVAR
| COEFi | Coefficient in design
variable and load relationship equation. Default = 1.0 (Real) |
- The relationship between analysis model loading and
design variable is:Where,
- The designed load
- The constant
- The coefficient
- The design variable
- Multiple loads with the same set of SID, G, and, ATT2 reference are not allowed. OptiStruct will error out in such cases.
- DVLREL1 and DVLREL2 entries are supported for Optimization based on Static Analysis only.
