Bulk Data Entries by Function
Guidelines for using Bulk Data Entries are listed in Bulk Data Guidelines.
The following table lists Bulk Data Entries according to data type.
Data Type Bulk Data Entry
Optimization BMFACE
CELL
DCOMP
DCONADD
DCONSTR
DDVAL
DEQATN
DESVAR
DESVARG
DGLOBAL
DLATTICE
DLINK
DLINK1
DLINK2
DOBJREF
DOPTPRM
DREPADD
DREPORT
DRESP1
DRESP2
DRESP3
DSCREEN
DSHAPE
DSHUFFLE
DSIZE
DSYSID
DTABLE
DTPG
DTPL
DVCREL1
DVCREL2
DVGRID
DVMBRL1
DVMBRL2
DVMREL1
DVMREL2
DVPREL1
DVPREL2
ESLTADD
ESLTIME
MODTRAK
Aero AECOMP
AECOMPL
AEFACT
AELINK
AELIST
AERO
AEROS
AESTAT
AESURF
CAERO1
CAERO2
DIVERG
DMI
FLFACT
FLUTTER
MKAERO1
MKAERO2
MONPNT1
MONPNT2
MONPNT3
MONSUM
MONSUM1
MONSUMT
SPLINE1
SPLINE2
SPLINE4
TRIM
Arbitrary Beam Section BEGIN
CSEC2
CSEC3
CSEC4
CSEC6
CSEC8
DIM
END
GRIDS
PSEC
Bodies RBADD RBODY
Constraints INLTVEL
JOINTG
MPC
MPCADD
MOTNJG
PERBC
SPC
SPC1
SPCADD
SPCOFF
SPCOFF1
SPCP
SUPORT
SUPORT1
Coordinate Systems CORD1C
CORD1R
CORD1S
CORD2C
CORD2R
CORD2S
CORD3R
CORD4R
Contact CLRNC
CNTITF
CNTLCK
CNTSTB
CONTACT
CONTPRM
PCONT
PCONTHT
PRSPENE
PSURF
SURF
TIE
Eigenvalue Analysis EIGC
EIGRA
EIGRD
EIGRL
Elements BCELL
CAABSF
CACINF3
CACINF4
CACONV
CACPML3
CACPML4
CAFLUID
CBAR
CBEAM
CBUSH
CBUSH1D
CDAMP1
CDAMP2
CDAMP3
CDAMP4
CELAS1
CELAS2
CELAS2F
CELAS3
CELAS4
CELAS4F
CFAST
CFASTG
CGAP
CGAPG
CGASK6
CGASK8
CGASK12
CGASK16
CHACAB
CHEXA
CIFHEX
CIFPEN
CMASS1
CMASS2
CMASS3
CMASS4
CONM1
CONM2
CPENTA
CPYRA
CQAXI
CQAXIG
CQPSTN
CQPSTS
CQUAD4
CQUAD8
CQUADR
CROD
CSEAM
CSHEAR
CTAXI
CTAXIG
CTETRA
CTPSTN
CTPSTS
CTRIA3
CTRIA6
CTRIAR
CTRIAX6
CTUBE
CVISC
CWELD
GENEL
MESHF
PACPML
PLOTEL
PLOTEL3
PLOTEL4
RBAR
RBE1
RBE2
RBE2GS
RBE3
RJOINT
RROD
RSPLINE
RSSCON
Fatigue Analysis FATDEF
FATEVNT
FATLOAD
FATPARM
FATSDR
FATSEAM
FATSEQ
MATFAT
MATFATT
PFAT
PFATSDR
PFATSMW
PFATSPW
TABFAT
Fluid Structure Modeling ACMODL
ELIST
FSI
MFLUID
Frequency Response Loads ACSRCE
DAREA
DELAY
DLOAD
DPHASE
FREQ
FREQ1
FREQ2
FREQ3
FREQ4
FREQ5
RLOAD1
RLOAD2
SLOAD
TABDMP1
TABDMP2
TABLED1
TABLED2
TABLED3
TABLED4
TABLEG
TABLEM1
TABLEM2
TABLEM3
TABLEM4
Grid and Scalar Points GRID
GRDSET
SPOINT
Heat Transfer Boundary Conditions CHBDYE
CNVGADD
CONV
CONVG
PCONV
PCONVLIB
RADBC
RADM
QBDY1
QBDYLIB
QVOL
QVOLLIB
SPC
SPC1
SPCDLIB
Includes INCLUDE
Materials MAT1
MAT1EC
MAT1PT
MATT1PT
MAT2
MAT2EC
MATT2PT
MAT2PT
MAT3
MAT4
MAT5
MAT8
MAT9
MAT9OR
MAT10
MATARU
MATBRT
MATF
MATF1
MATF2
MATF3
MATF8
MATF9
MATF10
MATFVE
MATHC
MATHE
MATHF
MATMDS
MATPE1
MATPZO
MATS1
MATT1
MATT1EC
MATT2
MATT2EC
MATT3
MATT4
MATT8
MATT9
MATT9OR
MATTHE
MATTPZO
MATTVE
MATTVP
MATUSHT
MATUSR
MATVE
MATVP
MCIRON
MCOHE
MCOHED
MGASK
TABLES1
TABLEST
Matrix Input DMIG
DMIGMOD
EL2MAT
EL2PROP
Modal Damping HYBDAMP TABDMP1
Matrix Reduction ASET
ASET1
BNDFIX
BNDFIX1
BNDFREE
BNDFRE1
BSET
BSET1
CDSMETH
CMSMETH
CSET
CSET1
CSUPEXT
EXTRN
SEBULK
SECONCT
SECSET
SECSET1
SELOC
SEQSET
SEQSET1
SESET
SETREE
USET
USET1
Metadata METADATA
Miscellaneous CYAX
CYCSET
CYJOIN
CYSYM
CYSYM
EDEM
INIPS
INISTRS
IPSADD
ISTSADD
LOADCYH
LOADCYN
MAP
MASSSET
MEFFSET
MODCHG
MODULE
MONCARL
MONDSP1
NLPCI
PLASTIC
SENSOR
SENSRAD
STEADY
TIE
TSTEPNL
Model Checks ELEMQUAL
Multibody Dynamics Entities CMBEAM
CMBEAMM
CMBUSH
CMBUSHC
CMBUSHE
CMBUSHM
CMBUSHT
CMSPDP
CMSPDPC
CMSPDPE
CMSPDPM
CMSPDPT
COUPLER
DTI,UNITS
GROUND
MARKER
MBDCRV
MBDSRF
MBPCRV
PFBODY
PRBODY
Multibody Dynamics Joints and Contacts JOINT
JOINTM
MBCNTDS
MBCNTR
MBCVCV
MBPTCV
MBPTDCV
MBPTDSF
Multibody Dynamics Loads and Motions INVELB
INVELJ
MBCRV
MBFRC
MBFRCC
MBFRCE
MBLIN
MBMNT
MBMNTC
MBMNTE
MBSFRC
MBSFRCC
MBSFRCE
MBSMNT
MBSMNTC
MBSMNTE
MBVAR
MLOAD
MOTION
MOTNG
MOTNGC
MOTNGE
MOTNJ
MOTNJC
MOTNJE
Multibody Dynamics Simulations and Requests MBACT
MBDEACT
MBREQ
MBREQE
MBREQM
MBSEQ
MBSIM
MBSIMP
Nonlinear Analysis BASELIN
DMGEVO
DMGINI
FLLWER
IMPERF
NLADAPT
NLCTRL
NLENRG
NLOUT
NLPARM
NLPRINT
TABLEMD
VISCO
Explicit Analysis
MONVOL
RSURF
Non-structural Mass, Damping NSGE
NSGE1
NSGEADD
NSM
NSM1
NSMADD
NSML
NSML1
One-step Stamping BLKHDF
EDGEBH
EDRAWB
FLDATA
MATHF
PHFSHL
Parameters GAPPRM
LATPRM
NLDEBUG
PARAM
PRETPRM
SWLDPRM
Parts and Instances
CONNECT
END
GMATCH
INSTANCE
PERBC
RELOC
Ply-based Composite Laminates DRAPE
PLY
STACK
Pretensioned Analysis PRETENS
PTADD
PTADJS1
PTADJST
PTFORCE
PTFORC1
Properties HOURGLS
MCELL
PAABSF
PACINF
PAERO1
PAERO2
PAFLUID
PAXI
PAXIG
PBAR
PBARL
PBEAM
PBEAML
PBUSH
PBUSHT
PBUSH1D
PBUSHFX
PCELL
PCOHE
PCOMP
PCOMPG
PCOMPLS
PCOMPP
PCONTEC
PCONTES
PCONTHT
PDAMP
PELAS
PELASFX
PELAST
PFAST
PFASTG
PGAP
PGAPEC
PGAPES
PGAPHT
PJOINTG
PLSOLID
PMASS
PPLANE
PROD
PSEAM
PSHEAR
PSHELL
PSOLID
PTUBE
PVISC
PWELD
Random Response RANDPS
RANDT1
RCROSS
TABRND1
Response Spectrum DTI,SPECSEL RSPEC
Rotor Dynamics RGYRO
ROTOR
ROTORG
RSPEED
RSPINR
RSPINT
UNBALNC
Set Definition SET
SET1
SET3
Solver Selection SOLVTYP
Special Outputs BORE
ERPPNL
MODOUT
PANEL
PANELG
PEAKOUT
PFPATH
RADSND
RADADD
SECTION
Static Loads ACCEL
ACCEL1
ACCEL2
CDENST4
CHARGE
CHGAREA
CHGVOL
CURRENT
DEFORM
FORCE
FORCE1
FORCE2
GRAV
LOAD
LOADADD
LOADJG
MOMENT
MOMENT1
MOMENT2
PLOAD
PLOAD1
PLOAD2
PLOAD4
PLOADE1
PLOADSF
PLOADX1
PLOADXG
RFORCE
SPCD
SPCF
TEMP
TEMPADD
TEMPD
TEMPP1
TEMPSEC
TEMPT
Transient Nonlinear Loads DAREA
DELAY
DLOAD
FILTER
NLRGAP
NOLIN1
NOLIN2
NOLIN3
NOLIN4
THIST
TIC
TICA
TLOAD1
TLOAD2
TSTEP
Units DTI,UNITS
