MONSUM1
Bulk Data Entry Defines a new monitor result that is the weighted sum of existing monitor results. The location of the computed MONSUM1 is specified.
The existing monitor points do not need to be of the same type but must be of a similar type. The results are printed to the .monpnt file.
| MONSUM1 | NAME | LABEL | |||||||
| CP | X | Y | Z | CD | |||||
| NEWAXISA | MTYPE1A | NAME1A | AXES1A | COEF1A | NAME2A | AXES2A | COEF2A | ||
| NAME3A | AXES3A | COEF3A | etc. | ||||||
| NEWAXISB | MTYPE1B | NAME1B | AXES1B | COEF1B | NAME2B | etc. | |||
| etc. |
Example: Create a new monitor point result by adding aerodynamic MONPNT1 and MONPNT3
| MONSUM1 | ROOT | SCALE FROM IN-LBS TO NEWTON-CM AND FROM LBS TO NEWTON | |||||||
| 500 | 0.0 | 25.0 | 20 | 200 | |||||
| 123456 | MONPNT3 | FS_1000 | 123 | -4.482 | FS_10000 | 356 | -11.385 | ||
| AMONPNT1 | ROOT | 123 | 4.482 | ROOT | 456 | 11.385 | |||
Alternate Format
| MTYPE | NEWAXISA | NAME1A | AXES1A | COEF1A | NAME2A | AXES2A | COEF2A | ||
| NEWAXISB | NAME1B | AXES1B | COEF1B | NAME2B | AXES2B | COEF2B | |||
| NAME3B | AXES3B | COEF3B | etc. |
Alternate Example: Create a new monitor point result by adding aerodynamic MONPNT1 and MONPNT3
| MONSUM1 | ROOT | Scale from in-lbs to newton-cm and from lbs to newtons | |||||||
| 500 | 0.0 | 25.0 | 20 | ||||||
| MONPNT3 | 123456 | FS_1000 | 123 | -4.482 | FS_1000 | 456 | -11.385 | ||
| AMONPNT1 | 123456 | ROOT | 123 | 4.482 | ROOT | 456 | 11.385 | ||
| NAME | Character string identifying the monitor point. No default (Character, a maximum of 8 characters) |
| LABEL | A character string that identifies and labels the monitor
point. Default = blank (Character, a maximum of 56 characters, fields 3 through 9) |
| CP | The identification number of a coordinate system in which the
input (X,Y,Z) coordinates are defined. Default = 0 (Integer > 0) |
| X, Y, Z | The coordinates in the CP coordinate system about which the
loads are monitored. Default = 0.0 (Real) |
| CD | The identification number of a coordinate system in which the
resulting load components are output. Default = Coordinate system specified by the CP field (Integer > 0) |
| NEWAXISj | The component axis of the newly created monitor point into
which the summed quantity is scored. (Integer > 0, up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks) |
| MTYPEij | Monitor type to be merged. No default (AMONONT1, AMONDSP1, SMONONT1, SMONDSP1) |
| NAMEij | Name of the monitored quantity to be merged. | |
| AXESij | Component axis to be summed. (Integer > 0, up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks) |
| COEFij | Coefficient to be applied to the components called out on
AXESij field. Default = 1.0 (Integer > 0) |
- The LABEL is a 56 character string that should be
unique. The result of the MONSUM1 entry is to create new
monitor points as:
- The merged monitor points must be of a similar type. "Similar" types
are defined as:
- Force and moment summation monitor points: AMONPNT1, SMONPNT1, MONPNT3.
- If multiple components are to be summed, the NEWAXISj field must be the union of subsequent AXESij fields. If the subsequent AXESij field is blank, the components are the same as NEWAXISj.
- If the NEWAXISj field indicates a single output, the AXESij fields must reference a single input, but it can be any value from 1 to 6. There may be as many as 6 AXESij and COEFij for each referenced NAMEij.
- The same component cannot be referenced multiple times on the NEWAXISj field for a single MONSUM1 entry.
- If multiple types are specified on a MONSUM1, the resulting entry is of a type that appears on the MONSUM1 with the following order of precedence: SMONPNT1 (structural MONPNT1), MONPNT3, AMONPNT1 (aerodynamic MONPNT1) , AMONDSP1. For example, an AMONPNT1 and a MONPNT3 appearing on the same entry results in a MONPNT3 regardless of which appears first.
- The CP, CD and X, Y, Z location coordinates are for reference only and do not affect the calculation.
