MATARU
Bulk Data Entry Defines parameters required for modelling an elasto-plastic, rate-dependent failure in an adhesive material.
MATARU MID E NU RHO
SIGNMAX GCN SIGSMAX GCS SHRP SH_SNL
PWRN PWRS EDOT0 EDOT1 SDFAC SGFAC
MID Material identification number.
No default (Integer > 0)
E Young's modulus.
No default (Real > 0.0)
NU Poisson’s ratio.
RHO Mass density.
SIGNMAX Maximum stress in normal direction.
Default = 1.E20 (Real > 0.0)
SIGSMAX Maximum stress in shear direction.
GCN Energy release rate in normal direction.
GCS Energy release rate in shear direction.
SHRP Shear plateau ratio.
Default = 0.0 (Real > 0.0)
SH_SNL Slope of yield surface for zero tension.
PWRN Power law term for normal direction.
Default = 2.0 ( > 0.0)
PWRS Power law term for shear direction.
Default = 2.0 (Real > 0.0)
EDOT0 Strain rate at which the static properties apply.
Default = 1.0 (Real > 0.0)
EDOT1 Strain rate at which the dynamic properties apply.
SDFAC Factor on SIGNMAX and SIGSMAX at strain rate EDOT1.
SGFAC Factor on GCN and GCS at strain rate EDOT1.
  1. MATARU must be used together with 3D interface elements CIFHEX/CIFPEN and cohesive element property PCOHE.
  2. Material response is similar to MCOHED up to yield and then differs according to the failure model defined.
  3. Adhesive thickness direction is assumed to be elemental Z- or element thickness direction.
