- ACCEL
Bulk Data Entry Defines acceleration loads to all grids in the model. These loads can either be constant or vary in a particular direction over sections of the model.
- ACCEL1
Bulk Data Entry Defines static acceleration loads at specific GRID points in the model.
- ACCEL2
Bulk Data Entry Defines static acceleration loads at a specific SET of GRID points in the model. Additionally, scale factors for varying direction acceleration loads can be defined using tabular data.
- ACMODL
Bulk Data Entry Defines model parameters for the fluid-structure interface.
- ACSRCE
Bulk Data Entry Defines acoustic source as a function of power versus frequency.
- AECOMP
Bulk Data Entry Defines a component for use in monitoring point definition or external splines.
- AECOMPL
- AEFACT
Bulk Data Entry Defines real numbers for Aeroelastic Analysis.
- AELINK
Bulk Data Entry Defines relationships between on among AESTAT and AESURF entries.
- AELIST
Bulk Data Entry Defines a list of aerodynamic box IDs.
- AERO
Bulk Data Entry Defines basic parameters for dynamic aeroelasticity.
- AEROS
Bulk Data Entry Defines basic parameters for static aeroelasticity.
- AESTAT
Bulk Data Entry Specifies rigid body motions to be used as trim variables in static aeroelasticity.
- AESURF
Bulk Data Entry Specifies an aerodynamic control surface as a member of the set of aerodynamic extra points. The forces associated with this controller will be derived from rigid rotation of the aerodynamic model about the hinge line(s).
- ASET
Bulk Data Entry Defines the boundary degrees-of-freedom of a superelement assembly for matrix reduction.
- ASET1
- BASELIN
Bulk Data Entry Corrects the acceleration record to avoid displacement shift.
- BCELL
Bulk Data Entry Defines a cell element.
- BEGIN
Bulk Data Entry Indicates the beginning of data that is used to describe a specific entity (or entities) for inclusion in a model. The BEGIN entry is used in conjunction with the END entry to define the data required for a specific entity.
- BLKHDF
Bulk Data Entry Defines the blank holder force in a one-step stamping simulation.
- BMFACE
Bulk Data Entry Defines quad or tria faces that are in turn used to define a barrier to limit the total deformation for free-shape design regions.
- BNDFIX
Bulk Data Entry Defines the degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
- BNDFIX1
Bulk Data Entry Defines the fixed (B-set) degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
- BNDFRE1
Bulk Data Entry Defines the free (C-set) degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
- BNDFREE
Bulk Data Entry Defines the degrees-of-freedom to be free during DMIG generation using CMSMETH card.
- BORE
Bulk Data Entry Defines the surface, coordinate system, and parameters required to request Bore Deformation output for Static Analysis Subcases.
- BSET
Bulk Data Entry Boundary Degrees-of-Freedom of a Superelement Assembly.
- BSET1
Bulk Data Entry Fixed Boundary Degrees-of-Freedom of a Superelement Assembly.
- CAABSF
Bulk Data Entry Defines the frequency-dependent fluid acoustic absorber element in coupled fluid-structural analysis.
- CACINF3
Bulk Data Entry Defines an Acoustic Infinite Element with a triangular base.
- CACINF4
Bulk Data Entry Defines an Acoustic Infinite Element with a quadrilateral base.
- CACONV
Bulk Data Entry Defines an interface for forced convection heat transfer using CAFLUID.
- CACPML3
Bulk Data Entry Defines an acoustic Adaptive Perfectly Matched Layer (APML) element with a triangular base.
- CACPML4
Bulk Data Entry Defines an acoustic Adaptive Perfectly Matched Layer (APML) element with a quadrilateral base.
- CAERO1
Bulk Data Entry Defines an aerodynamic macro element (panel) for lifting bodies in terms of two leading edge locations and side chords. This is used for Vortex Lattice Method (VLM) and Doublet Lattice Method (DLM) in subsonic aeroelastic analysis and for Constant Pressure Method (CPM) in supersonic aeroelastic analysis.
- CAERO2
Bulk Data Entry Defines aerodynamic slender body and interference elements for Doublet-Lattice aerodynamics.
- CAFLUID
Bulk Data Entry Defines a 1D element that can conduct heat and transmit fluid between its two primary nodes.
- CBAR
Bulk Data Entry Defines a simple beam element (BAR) of the structural model.
- CBEAM
Bulk Data Entry Defines a beam element (BEAM) of the structural model.
- CBEND
Bulk Data Entry Defines a curved beam or pipe element of the structural model.
- CBUSH
Bulk Data Entry Defines a generalized spring-damper structural element.
- CBUSH1D
Bulk Data Entry Defines a one-dimensional spring-damper structural element.
- CDAMP1
Bulk Data Entry Defines a scalar damper element.
- CDAMP2
Bulk Data Entry Defines a scalar damper element without reference to a property entry.
- CDAMP3
Bulk Data Entry Defines a scalar damper element that is connected only to scalar points.
- CDAMP4
Bulk Data Entry Defines a scalar damper element that is connected only to scalar points and is without reference to a material or property entry.
- CDENST4
Bulk Data Entry Defines a current density on the face of solid elements (HEXA, PENTA, TETRA, PYRA) or on the side of shell elements (TRIA3, TRIA6, QUAD4, QUAD8), in Electrical analysis.
- CDSMETH
Bulk Data Entry Can be used in the component dynamic synthesis method for generating component dynamic matrices at each loading frequency.
- CELAS1
Bulk Data Entry Defines a scalar spring element of the structural model.
- CELAS2
Bulk Data Entry Defines a scalar spring element of the structural model without reference to a property entry.
- CELAS2F
Bulk Data Entry Defines a scalar spring element of the structural model without reference to a property entry. The corresponding properties on this entry are not affected by translational and rotational stiffness limits specified using PARAM,ELASSTIF.
- CELAS3
Bulk Data Entry Defines a scalar spring element that connects only to scalar points.
- CELAS4
Bulk Data Entry Defines a scalar spring element that is connected only to scalar points without reference to a property entry.
- CELAS4F
Bulk Data Entry Defines a scalar spring element that is connected only to scalar points without reference to a property entry. The corresponding properties on this entry are not affected by translational and rotational stiffness limits specified using PARAM,ELASSTIF.
- CELL
Bulk Data Entry Defines a unit cell comprised of lattice entities which can be used for space filling via the DLATTICE entry.
- CFAST
Bulk Data Entry Define a fastener with material orientation connecting two shell surfaces.
- CFASTG
Bulk Data Entry Defines a fastener which can be used to model connections such as spot welds, rivets, bolts and so on.
- CGAP
Bulk Data Entry Defines a gap or friction element.
- CGAPG
Bulk Data Entry Defines a node-to-obstacle gap element. The obstacle may be an element face or a patch of nodes.
- CGASK6
Bulk Data Entry Defines the connections of the GASK6 solid gasket element.
- CGASK8
Bulk Data Entry Defines the connections of the GASK8 solid gasket element.
- CGASK12
Bulk Data Entry Defines the connections of the GASK12 solid gasket element.
- CGASK16
Bulk Data Entry Defines the connections of the GASK16 solid gasket element.
- CHACAB
Bulk Data Entry Defines the acoustic absorber element in coupled fluid-structural analysis.
- CHARGE
Bulk Data Entry Defines a point electric charge at a grid or a set of grids.
- CHBDYE
Bulk Data Entry Defines a surface element for application of thermal boundary condition.
- CHEXA
Bulk Data Entry Defines the connections of the HEXA solid element.
- CHGAREA
Bulk Data Entry Defines the charge density on faces of CHEXA, CPENTA, CTETRA, or CPYRA solid elements.
- CHGVOL
Bulk Data Entry Defines the charge density on a volume of CHEXA, CPENTA, CTETRA, or CPYRA solid elements.
- CIFHEX
Bulk Data Entry Defines the connections of the cohesive element.
- CIFPEN
- CLRNC
Bulk Data Entry Defines parameters for clearance and threaded bolts geometry.
- CMASS1
Bulk Data Entry Defines a scalar mass element.
- CMASS2
Bulk Data Entry Defines a scalar mass element without reference to a property entry.
- CMASS3
Bulk Data Entry Defines a scalar mass element that is connected only to scalar points.
- CMASS4
Bulk Data Entry Defines a scalar mass element that is connected only to scalar points, without reference to a property entry.
- CMBEAM
Bulk Data Entry Defines a beam element for multibody dynamics solution sequence without reference to a property entry.
- CMBEAMM
Bulk Data Entry Defines a beam element for multibody dynamic solution sequence without reference to a property entry based on markers.
- CMBUSH
Bulk Data Entry Defines a bushing element without reference to a property entry.
- CMBUSHC
- CMBUSHE
- CMBUSHM
Bulk Data Entry Defines a bushing element without reference to a property entry based on markers.
- CMBUSHT
- CMSMETH
Bulk Data Entry Defines the CMS (Component Mode Synthesis) method, frequency upper limit, number of modes, and starting SPOINT ID to be used in a CMS solution.
- CMSPDP
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence.
- CMSPDPC
- CMSPDPE
- CMSPDPM
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence based on marker.
- CMSPDPT
- CNTITF
Bulk Data Entry Defines parameters for contact (S2S and N2S) interference.
- CNTLCK
Bulk Data Entry Defines parameters for the contact (S2S and N2S) lock in the preloaded Linear Analysis subcase.
- CNTSTB
Bulk Data Entry Defines parameters for stabilization control of contact (S2S and N2S) and gap elements (CGAP/CGAPG). This entry is supported with nonlinear static and nonlinear transient analysis types for both small and large displacement cases.
- CNVGADD
Bulk Data Entry Allows referencing a combined free convection definition via multiple CONVG Bulk Data Entries.
- CONM1
Bulk Data Entry Defines a 6x6 mass matrix at a geometric grid point.
- CONM2
Bulk Data Entry Defines a concentrated mass at a grid point of the structural model.
- CONNECT
Bulk Data Entry Define equivalence for degrees of freedom of grid points of two sections of the same model (Format 2) or different parts in a Parts and Instances Model (Format 1) within a specified tolerance.
- CONROD
Bulk Data Entry Defines a rod element without reference to a property entry.
- CONTACT
Bulk Data Entry Defines a contact interface.
- CONTPRM
Bulk Data Entry Defines the default properties of all contacts and sets parameters that affect all contacts.
- CONV
Bulk Data Entry Defines a free convection boundary condition for heat transfer analysis through connection to a surface element (CHBDYE card).
- CONVG
Bulk Data Entry Defines Free convection via automatic generation of free convection entries. This entry also supports subcase-dependent free convection.
- CORD1C
Bulk Data Entry Defines a cylindrical coordinate system using three grid points. The first point is the origin, the second lies on the Z-axis, and the third lies in the X-Z plane.
- CORD1R
Bulk Data Entry Defines a rectangular coordinate system using three grid points. The first point is the origin, the second lies on the Z-axis, and the third lies in the X-Z plane.
- CORD1S
Bulk Data Entry Defines a spherical coordinate system using three grid points. The first point is the origin, the second lies on the Z-axis, and the third lies in the X-Z plane.
- CORD2C
Bulk Data Entry Defines a cylindrical coordinate system using three grid points specified with respect to a reference coordinate system.
- CORD2R
Bulk Data Entry Defines a rectangular coordinate system by using three grid points.
- CORD2S
Bulk Data Entry Defines a spherical coordinate system three grid points.
- CORD3R
Bulk Data Entry Defines a rectangular coordinate system using three grid points. The first point is the origin, the second lies on the X-axis, and the third lies in the X-Y plane.
- CORD4R
Bulk Data Entry Defines a rectangular coordinate system using three grid points specified with respect to the basic coordinate system.
- COUPLER
Bulk Data Entry Defines a coupler connecting two or three joints.
- CPENTA
Bulk Data Entry Defines the connections of the CPENTA element.
- CPYRA
Bulk Data Entry Defines the connections of the PYRA solid element.
- CQAXI
Bulk Data Entry Defines a 2D axisymmetric quadrilateral cross-section ring element.
- CQAXIG
Bulk Data Entry Defines a quadrilateral cross-section general axisymmetric element that allows circumferential deformation.
- CQPSTN
Bulk Data Entry Defines a plane strain quadrilateral element in x-z or x-y plane.
- CQPSTS
Bulk Data Entry Plane stress quadrilateral element connection. Defines a plane stress quadrilateral element in the x-z or x-y plane.
- CQUAD4
Bulk Data Entry Defines a quadrilateral plate element (QUAD4) of the structural model. This element uses a 6 degree-of-freedom per node formulation.
- CQUAD8
Bulk Data Entry Defines a curved quadrilateral shell element with eight grid points.
- CQUADR
Bulk Data Entry Equivalent to CQUAD4. Unlike other Nastran codes, a 6 degree-of-freedom per node formulation is used for all shell elements.
- CROD
Bulk Data Entry Defines a tension-compression-torsion element (ROD) of the structural model.
- CSEAM
Bulk Data Entry Defines a seam weld connecting two shell surfaces.
- CSEC2
Bulk Data Entry Defines a two-noded element used in the definition of arbitrary beam cross-sections.
- CSEC3
Bulk Data Entry Defines a 1st order, three-noded element used in the definition of arbitrary beam cross-sections.
- CSEC4
Bulk Data Entry Defines a 1st order, four-noded element used in the definition of arbitrary beam cross-sections.
- CSEC6
Bulk Data Entry Defines a planar, 2nd order, six-noded element used in the definition of arbitrary beam cross-sections.
- CSEC8
Bulk Data Entry Defines a planar 2nd order, eight-noded element used in the definition of arbitrary beam cross-sections.
- CSET
- CSET1
- CSHEAR
Bulk Data Entry Defines a shear panel element.
- CSUPEXT
Bulk Data Entry Defines the Exterior grid points for One-Step Superelement Analysis.
- CTAXI
Bulk Data Entry Defines an axisymmetric triangular cross-section ring element.
- CTAXIG
Bulk Data Entry Defines a triangular cross-section general axisymmetric element that allows circumferential deformation.
- CTETRA
Bulk Data Entry Defines the connections of the CTETRA element.
- CTPSTN
Bulk Data Entry Defines a plane strain triangular element in x-z or x-y plane.
- CTPSTS
Bulk Data Entry Plane stress triangular element connection. Defines a plane stress triangular element in the x-z or x-y plane.
- CTRIA3
Bulk Data Entry Defines a triangular plate element (TRIA3) of the structural model. This element uses a 6 degree-of-freedom per node formulation.
- CTRIA6
Bulk Data Entry Defines a curved triangular shell element with six grid points.
- CTRIAR
Bulk Data Entry CTRIAR entry is equivalent to CTRIA3. Unlike other Nastran codes, a 6 degrees-of-freedom per node formulation is used for all shell elements.
- CTRIAX6
- CTUBE
Bulk Data Entry Defines a tension-compression-torsion element (TUBE) of the structural model.
- CURRENT
Bulk Data Entry Defines a static point current at a grid or a set of grids, by specifying a vector, in Electrical analysis.
- CVISC
Bulk Data Entry Defines a viscous damper element.
- CWELD
Bulk Data Entry Defines a weld or fastener connecting two surface patches or points.
- CYAX
Bulk Data Entry Used to list the grids that lie on the axis of symmetry, in cyclic symmetry analysis.
- CYCSET
Bulk Data Entry Defines surface pairs for TIE-based cyclic symmetry boundary constraints.
- CYJOIN
Bulk Data Entry Defines points on one of the boundaries that connect to adjacent segments in cyclic symmetry analysis.
- CYSYM
Bulk Data Entry Specifies the number of segments, in a cyclic symmetry analysis.
- DAREA
Bulk Data Entry Defines scale (area) factors for dynamic loads. DAREA is used in conjunction with RLOAD1, RLOAD2, TLOAD1, and TLOAD2 entries.
- DCOMP
Bulk Data Entry Defines manufacturing constraints for composite sizing optimization.
- DCONADD
Bulk Data Entry Creates a combination of several DCONSTR sets that can be referenced by a subcase.
- DCONSTR
Bulk Data Entry Defines design constraint upper and lower bounds where response is defined by DRESP1, DRESP2, and DRESP3 cards.
- DDVAL
Bulk Data Entry Define real, discrete design variable values for discrete variable optimization or to define relative rotor spin rates in rotor dynamics.
- DEFORM
Bulk Data Entry Defines enforced axial deformation for one-dimensional elements for use in statics problems.
- DELAY
Bulk Data Entry Defines the time delay term in the equations of the dynamic loading function. DELAY is used in conjunction with RLOAD1, RLOAD2, TLOAD1, and TLOAD2 entries.
- DEQATN
Bulk Data Entry Specifies one or more equations for use in optimization.
- DESVAR
Bulk Data Entry Defines a design variable.
- DESVARG
Bulk Data Entry Defines an override for design variable settings.
- DGLOBAL
Bulk Data Entry Defines input parameters required for the Global Search Option (GSO).
- DIM
Bulk Data Entry Defines a link between a DIM# field on a PBARL or PBEAML property and either the thickness on a PSEC definition or the y or z coordinate on a GRIDS definition; it is used in the definition of arbitrary beam cross-sections.
- DIVERG
Bulk Data Entry Specifies the number of Divergence pressures and Mach numbers for a static aeroelastic divergence analysis.
- DLATTICE
Bulk Data Entry Defines parameters for filling a space with lattice-based unit cells. The presence of this entry also activates the creation of unit cells to fill the target volume.
- DLINK
Bulk Data Entry Defines a link between one design variable and one or more other design variables.
- DLINK1
- DLINK2
Bulk Data Entry Defines a link of one design variable to one or more other design variables defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
- DLOAD
Bulk Data Entry Defines a dynamic loading condition for frequency response problems as a linear combination of load sets defined via RLOAD1 and RLOAD2 entries, or for transient problems as a linear combination of load sets defined via TLOAD1 and TLOAD2 entries, or acoustic source ACSRCE entries.
- DMGEVO
Bulk Data Entry Defines the damage evolution.
- DMGINI
Bulk Data Entry Defines the damage initiation criteria.
- DMI
Bulk Data Entry Defines matrix (real) data blocks for Aeroelastic Analysis.
- DMIG
Bulk Data Entry Defines direct input matrices related to grid points. The matrix is defined by a single header entry and one or more column entries. A column entry is required for each column with non-zero elements.
- DMIGMOD
Bulk Data Entry Defines changes in the contents of a super element from H3DDMIG input.
- DMIGROT
Bulk Data Entry Controls rotation and other specifications for a matrix entered using DMIG entry.
- DOBJREF
Bulk Data Entry Defines a response and its reference values for a minmax (maxmin) optimization problem.
- DOPTPRM
Bulk Data Entry Defines design optimization parameters by overriding the defaults.
- DPHASE
Bulk Data Entry Defines the phase lead term in the equation of the dynamic loading function. DPHASE is used in conjunction with RLOAD1 and RLOAD2 entries.
- DRAPE
Bulk Data Entry Defines the draping data for plies used in ply-based composite definition.
- DREPADD
Bulk Data Entry Creates a combination of several DREPORT sets that can be referenced by a subcase.
- DREPORT
Bulk Data Entry Used in the Bulk Data section to report responses, defined by DRESP1, DRESP2 and DRESP3 cards, to the output file, which are not constrained or used as the objective function, as defined by the optimization problem.
- DRESP1
Bulk Data Entry A response or a set of responses that are the result of a design analysis iteration. These responses can be used as a design objective or as design constraints.
- DRESP2
Bulk Data Entry When a desired response is not directly available from OptiStruct, it may be calculated using DRESP2.
- DRESP3
Bulk Data Entry The DRESP3 card identifies the external function to be called and defines the parameters to be transferred to that function.
- DSCREEN
Bulk Data Entry Defines design response screening data.
- DSHAPE
Bulk Data Entry Defines parameters for classic and grid-based free-shape design variables.
- DSHUFFLE
Bulk Data Entry Defines parameters for the generation of composite shuffling design variables.
- DSIZE
Bulk Data Entry Defines parameters for the generation of free-size design variables.
- DSYSID
Bulk Data Entry Defines responses and their target values for a system identification problem.
- DTABLE
Bulk Data Entry List of constants to be used in functions defined by DEQATN.
- DTI,SPECSEL
Bulk Data Entry Correlates spectra lines specified on TABLED1 entries with damping values.
- DTI,UNITS
Bulk Data Entry Defines units for multibody, component mode synthesis (flexible-body preparation), and Explicit Dynamic Analysis sequences.
- DTPG
Bulk Data Entry Defines parameters for the generation of topography design variables.
- DTPL
Bulk Data Entry Defines parameters for the generation of topology design variables.
- DTRUSS
Bulk Data Entry Activates Truss Layout Optimization and defines the corresponding parameters for design optimization, including truss cross-sectional area limits, stress, symmetry, and buckling constraints.
- DVCREL1
Bulk Data Entry Relates Design Variables to Analysis Model Element Properties
- DVCREL2
Bulk Data Entry Relates design variables to an analysis model element property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and constants defined on a DTABLE card.
- DVCREL - Types
- DVGRID
Bulk Data Entry Defines the relationship between a design variable and a grid point location.
- DVLREL1
Bulk Data Entry Linearly relates a design variable to an analysis model loading.
- DVLREL2
Bulk Data Entry Relates a design variable to an analysis model loading using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
- DVMBRL1
Bulk Data Entry Linearly relates a design variable to properties of an MBD entity using the equation:
- DVMBRL2
Bulk Data Entry Relates a design variable to properties of MBD entities using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
- DVMREL1
Bulk Data Entry Linearly relates a design variable to an analysis model material property using the equation:
- DVMREL2
Bulk Data Entry Relates design variables to an analysis model material property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and constants defined on a DTABLE card.
- DVMREL - Types
- DVPREL1
Bulk Data Entry Relates Design Variables to Analysis Model Properties
- DVPREL2
Bulk Data Entry Relates a design variable to an analysis model property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
- DVPREL - Types
- EDEM
Bulk Data Entry Defines the parameters required to activate coupling between OptiStruct and EDEM.
- EDGEBH
Bulk Data Entry Defines geometry and restraining force per unit length for an edge blank holder in a one-step stamping simulation.
- EDRAWB
Bulk Data Entry Defines location and restraining force per unit length for a draw bead in a one-step stamping simulation.
- EIGC
Bulk Data Entry Defines data required to perform complex eigenvalue analysis.
- EIGRA
Bulk Data Entry Defines the data required to perform real eigenvalue analysis with the Automated Multi-Level Sub-structuring technique.
- EIGRD
Bulk Data Entry Defines data required to perform eigenvalue extraction using the Lapack-based dense solver.
- EIGRL
Bulk Data Entry Defines data required to perform real eigenvalue analysis (vibration or buckling) with the Lanczos method.
- EL2MAT
Bulk Data Entry Used to assign material ID to elements.
- EL2PROP
Bulk Data Entry Used to assign property ID to elements in DMIG.
- ELEMQUAL
Bulk Data Entry Resets the default values of the warning and error bound limits for element quality check.
- ELIST
Bulk Data Entry Specifies damp shell elements for a fluid volume. ELIST entries are referenced by the MFLUID entry.
- END
Bulk Data Entry The END Bulk Data Entry indicates the end of data that is used to describe a specific entity (or entities) for inclusion in a model. The END entry is used in conjunction with the BEGIN entry to define the data required for a specific entity.
- ERPPNL
Bulk Data Entry Defines one or more sets of elements as panels for equivalent radiated power output for a frequency response analysis.
- ESLTADD
Bulk Data Entry Defines a combined time step selection set as a union of selected time steps defined via ESLTIME entries for Geometric Nonlinear ESLM optimization or a Multibody Dynamics ESLM optimization.
- ESLTIME
Bulk Data Entry Defines time step selection control for geometric nonlinear response ESL Optimization and Multibody dynamics ESLM optimization.
- EXTRN
Bulk Data Entry Defines boundary connections for an external superelement.
- FATDEF
Bulk Data Entry Defines elements or grids, and associated fatigue properties, for consideration in a fatigue analysis.
- FATEVNT
Bulk Data Entry Defines loading events for Fatigue Analysis.
- FATLOAD
Bulk Data Entry Defines fatigue loading parameters.
- FATPARM
Bulk Data Entry Used to define parameters required for a Fatigue Analysis.
- FATSDR
Bulk Data Entry Defines the solder joint for consideration in solder fatigue analysis.
- FATSEAM
Bulk Data Entry Used to define parameters and property identification data for Seam Weld Fatigue Analysis.
- FATSEQ
Bulk Data Entry Defines a loading sequence for a Fatigue Analysis.
- FILTER
Bulk Data Entry Defines filtering rules for time history output request for an explicit analysis.
- FLDATA
Bulk Data Entry Defines a forming limit curve as a table of minor and major strain values in a one-step stamping simulation.
- FLFACT
Bulk Data Entry Used to specify the aerodynamic factors in aerodynamic flutter analysis.
- FLLWER
Bulk Data Entry Defines parameters for the calculation follower loads in large displacement nonlinear analysis.
- FLUTTER
Bulk Data Entry Used to specify the parameters required for aerodynamic flutter analysis.
- FORCE
Bulk Data Entry Defines a static force at a grid point or a SET of grid points by specifying a vector.
- FORCE1
Bulk Data Entry Used to define a static force by specification of a value and two grid points that determine the direction.
- FORCE2
Bulk Data Entry Used to define a static force by specification of a value and four grid points that determine the direction.
- FREQ
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems.
- FREQ1
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, frequency increment, and the number of increments desired.
- FREQ2
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, final frequency, and the number of logarithmic increments desired.
- FREQ3
Bulk Data Entry Defines a set of frequencies for the modal method of frequency response analysis by specifying the number of frequencies between modal frequencies.
- FREQ4
Bulk Data Entry Defines a set of frequencies for the modal method of frequency response analysis by specifying the amount of "spread" around each modal frequency and the number of equally spaced frequencies within the spread.
- FREQ5
Bulk Data Entry Defines a set of frequencies for the modal method of frequency response analysis by specification of a frequency range and fractions of the natural frequencies within that range.
- FSI
Bulk Data Entry Defines the settings for Fluid-Structure Interaction Analysis with AcuSolve.
- GAPPRM
Bulk Data Entry Defines parameters that control connectivity and configuration checks for gap elements (CGAP and CGAPG). Most of these parameters also affect contact elements that are automatically created on CONTACT interfaces - see individual descriptions for details.
- GENEL
Bulk Data Entry Defines the stiffness, flexibility, mass, viscous damping, or structural damping of a general element connected to an arbitrary number of grids.
- GMATCH
Bulk Data Entry Defines equivalence for all degrees of freedom of grid points of two different subsets of without any requirement that these two subsets are closely located to one another.
- GRAV
Bulk Data Entry Defines the gravity vectors for use in determining gravity loading for the static structural model. It can also be used to define the EXCITEID field (Amplitude "A") of dynamic loads in RLOAD1, RLOAD2, TLOAD1, TLOAD2 and NLOAD1 Bulk Data Entries for dynamic solution sequences.
- GRDSET
Bulk Data Entry Defines default options for fields 3, 7, and 8 of all GRID entries.
- GRID
Bulk Data Entry Defines the location of a geometric grid point of the structural model, the directions of its displacement, and its permanent single-point constraints or permanent zero electric potential.
- GRIDS
Bulk Data Entry Defines a grid point on the y-z plane, using cartesian coordinates, for use in the definition of arbitrary beam cross-sections.
- GROUND
Bulk Data Entry Defines a ground body out of a list of finite element properties, elements, and grid points.
- HOURGLS
Bulk Data Entry Defines hourglass control parameters to reduce spurious zero-energy modes in elements with reduced integration.
- HYBDAMP
Bulk Data Entry Defines the application of modal damping to the residual structure in a Direct Transient or Frequency Response analysis.
- IMPERF
Bulk Data Entry Define the initial geometric imperfection at the beginning of a nonlinear analysis.
- INCLUDE
Bulk Data Entry This Bulk Data card is identical to the I/O Options Entry, INCLUDE.
- INIPS
Bulk Data Entry Defines initial plastic strain values and settings for elements in nonlinear analysis.
- INISTRS
Bulk Data Entry Defines initial stress values and settings for elements in nonlinear analysis.
- INLTVEL
Bulk Data Entry Defines the Inlet velocity for Darcy Flow Analysis.
- INSTNCE
Bulk Data Entry The INSTNCE Bulk Data Entry can be used to define the location of a part in the global structure. Each INSTNCE entry should reference a unique part name.
- INVELB
Bulk Data Entry Defines initial velocity in a multibody situation.
- INVELJ
Bulk Data Entry Defines initial velocity of a joint in a multibody situation.
- IPSADD
Bulk Data Entry Defines initial plastic strain condition for nonlinear static analysis as a union of INIPS entries.
- ISTSADD
Bulk Data Entry Defines initial stress condition for nonlinear quasi-static analysis as a union of INISTRS entries.
- JOINT
Bulk Data Entry Defines a joint for Multibody Dynamics.
- JOINTG
Bulk Data Entry Defines a joint connection between two grids.
- JOINTM
Bulk Data Entry Defines a joint using two grids which have a marker card associated with them. Joints are only valid in a multibody solution sequence.
- LATPRM
Bulk Data Entry Defines the parameters available for Lattice Optimization Control.
- LOAD
Bulk Data Entry The LOAD is equivalent to the LOADADD.
- LOADADD
Bulk Data Entry Defines a static load as a linear combination of load sets defined via FORCE, MOMENT, FORCE1, MOMENT1, PLOAD, PLOAD1, PLOAD2, PLOAD4, RFORCE, DAREA, ACCEL, ACCEL1, ACCEL2, GRAV, SPCF, and LOADADD entries.
- LOADCYH
Bulk Data Entry Used to define the loading by harmonics in cyclic symmetry analysis.
- LOADCYN
Bulk Data Entry Used to define the loading by segments in cyclic symmetry analysis.
- LOADJG
Bulk Data Entry Defines loading for joint connector JOINTG Bulk Data Entry.
- LOCATE
Bulk Data Entry The LOCATE Bulk Data Entry can be used to define the location of a part in the global structure. Each LOCATE entry should reference a unique part name. LOCATE Bulk Data Entries are activated in each subcase by the LOCATE Subcase Entry.
- MAP
Bulk Data Entry Used to map results to the model (OptiStruct) from other external result files.
- MARKER
Bulk Data Entry Define a marker by associating a grid and a coordinate system.
- MASSSET
Bulk Data Entry Defines a linear combination of mass cases to form the subcase dependent mass.
- MAT1
Bulk Data Entry Defines the material properties for linear, temperature-independent, and isotropic materials.
- MAT1EC
Bulk Data Entry Defines constant electrical material properties for resistivity and Joule heat fraction in electrical analysis.
- MAT1PT
Bulk Data Entry Defines isotropic permittivity and damping for dielectric materials.
- MAT2
Bulk Data Entry Defines the material properties for linear, temperature-independent, and anisotropic materials for two-dimensional elements.
- MAT2EC
Bulk Data Entry Defines the electrical material properties for anisotropic materials in electrical analysis.
- MAT2PT
Bulk Data Entry Defines anisotropic permittivity and damping for dielectric materials
- MAT3
Bulk Data Entry Defines the material properties for linear, temperature-independent, and orthotropic materials used by the CTAXI, CTRIAX6, CQAXI, CTAXIG, and CQAXIG axisymmetric elements, and CTPSTN and CQPSTN plane strain elements.
- MAT4
Bulk Data Entry Defines constant thermal material properties for conductivity, density, and heat generation.
- MAT5
Bulk Data Entry Defines the thermal material properties for anisotropic materials.
- MAT8
Bulk Data Entry Defines the material properties for linear temperature-independent orthotropic material for two-dimensional elements.
- MAT9
Bulk Data Entry Defines the material properties for linear, temperature-independent, and anisotropic materials for solid elements.
- MAT9OR
Bulk Data Entry Defines the material properties for linear, temperature-independent, and orthotropic materials for solid elements in terms of engineering constants.
- MAT10
Bulk Data Entry Defines material properties for fluid elements in coupled fluid-structural analysis.
- MATARU
Bulk Data Entry Defines parameters required for modelling an elasto-plastic, rate-dependent failure in an adhesive material.
- MATBRT
Bulk Data Entry Defines the material properties for Brittle Damage material models.
- MATF
Bulk Data Entry Defines material properties and failure model parameters for Failure criteria calculations.
- MATFAT
Bulk Data Entry Defines material properties for fatigue analysis.
- MATFATT
Bulk Data Entry Defined temperature-dependent material properties for fatigue analysis.
- MATF1
Bulk Data Entry Specifies frequency-dependent material properties on MAT1 entry fields via TABLEDi entries.
- MATF2
Bulk Data Entry Specifies frequency-dependent material properties on MAT2 entry fields via TABLEDi entries.
- MATF3
Bulk Data Entry Specifies frequency-dependent material properties on MAT3 entry fields via TABLEDi entries.
- MATF8
Bulk Data Entry Specifies frequency-dependent material properties on MAT8 entry fields via TABLEDi entries.
- MATF9
Bulk Data Entry Specifies frequency-dependent material properties on MAT9 entry fields via TABLEDi entries.
- MATF10
Bulk Data Entry Specifies frequency-dependent material properties on MAT10 entry fields via TABLEDi entries.
- MATFVE
Bulk Data Entry Defines material properties for frequency-dependent viscoelastic materials.
- MATHC
Bulk Data Entry This material data defines honeycomb material behavior in Explicit analysis.
- MATHE
Bulk Data Entry Defines material properties for nonlinear hyperelastic materials. The Polynomial form is available and various material types
3 can be defined by specifying the corresponding coefficients.
- MATHF
Bulk Data Entry Defines the material properties in a one-step stamping simulation.
- MATMDS
Bulk Data Entry Defines material properties and parameters through an interface to Altair Multiscale Designer® allowing you to include a much wider range of different material models.
- MATPE1
Bulk Data Entry Defines the material properties for poro-elastic materials.
- MATPZO
Bulk Data Entry Defines the coupling terms between structural and dielectric materials for defining a piezoelectric coupling.
- MATS1
Bulk Data Entry Specifies strain-, rate-, and temperature-dependent material properties for use in applications involving nonlinear materials.
- MATT1
Bulk Data Entry Specifies temperature-dependent material properties on MAT1 entry fields via TABLEMi or TABLEG entry.
- MATT1EC
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MAT1EC Bulk Data Entry fields via TABLEMi or TABLEG entries.
- MATT1PT
Bulk Data Entry Defines temperature-dependent isotropic permittivity via the TABLEM1-4 or TABLEG Bulk Data Entries for dielectric materials.
- MATT2
Bulk Data Entry Specifies temperature-dependent material properties on MAT2 entry fields via TABLEMi or TABLEG entry.
- MATT2EC
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MAT2EC Bulk Data Entry fields via TABLEMi or TABLEG entries.
- MATT2PT
Bulk Data Entry Defines temperature-dependent anisotropic permittivity via the TABLEM1-4 or TABLEG Bulk Data Entries for dielectric materials.
- MATT3
Bulk Data Entry Specifies temperature-dependent material properties on MAT3 entry fields via TABLEMi or TABLEG entry.
- MATT4
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MAT4 Bulk Data Entry fields via TABLEMi or TABLEG entry.
- MATT8
Bulk Data Entry Specifies temperature-dependent material properties on MAT8 entry fields via TABLEMi or TABLEG entry.
- MATT9
Bulk Data Entry Specifies temperature-dependent material properties on MAT9 entry fields via TABLEMk or TABLEG entry.
- MATT9OR
Bulk Data Entry Specifies temperature-dependent material properties on MAT9OR entry fields via TABLEMk or TABLEG entry.
- MATTHE
Bulk Data Entry Defines material properties for temperature-dependent nonlinear hyperelastic materials.
- MATTPZO
Bulk Data Entry Defines temperature-dependent coupling terms between structural and dielectric materials, for defining a piezoelectric coupling.
- MATTVE
Bulk Data Entry Defines material properties for temperature-dependent nonlinear viscoelastic materials.
- MATTVP
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MATVP Bulk Data Entry fields via TABLEMi or TABLEG entry.
- MATUSHT
Bulk Data Entry Defines thermal material properties and parameters for user-defined thermal material.
- MATUSR
Bulk Data Entry Defines material properties and parameters for user-defined structural material.
- MATVE
Bulk Data Entry Defines material properties for nonlinear viscoelastic materials.
- MATVP
Bulk Data Entry Defines material properties for nonlinear creep materials.
- MBACT
Bulk Data Entry Defines the entity/set that needs to be activated in the multibody system for the subsequent simulation.
- MBCNTDS
Bulk Data Entry Defines a Multibody Contact between a set of nodes and a deformable surface.
- MBCNTR
Bulk Data Entry Defines a Multibody contact between rigid bodies.
- MBCRV
Bulk Data Entry Specifies the data used to define a curve.
- MBCVCV
Bulk Data Entry Defines a Curve to Curve Constraint.
- MBDCRV
Bulk Data Entry Defines an ordered list of grids as a Multibody Deformable Curve.
- MBDEACT
Bulk Data Entry Defines the entity/set that needs to be deactivated in the multibody system for the subsequent simulation.
- MBDSRF
Bulk Data Entry Defines a multibody deformable surface.
- MBFRC
Bulk Data Entry Defines a constant force at a grid point by specifying a vector.
- MBFRCC
Bulk Data Entry Defines a curve force at a grid point by specifying a vector.
- MBFRCE
Bulk Data Entry Defines an expression force at a grid point by specifying a vector.
- MBLIN
Bulk Data Entry Defines the parameters for a multibody system linear analysis.
- MBMNT
Bulk Data Entry Defines a constant moment at a grid point by specifying a vector.
- MBMNTC
Bulk Data Entry Defines a curve moment at a grid point by specifying a vector.
- MBMNTE
Bulk Data Entry Defines an expression moment at a grid point by specifying a vector.
- MBPCRV
Bulk Data Entry Defines a Multibody Parametric Curve using node sets.
- MBPTCV
Bulk Data Entry Defines a Point to Parametric Curve Constraint.
- MBPTDCV
Bulk Data Entry Defines a Point to Deformable Curve Constraint.
- MBPTDSF
Bulk Data Entry Defines a Point to Deformable Surface Constraint.
- MBREQ
Bulk Data Entry Defines a multibody as a combination of request sets defined via MBREQE and MBREQM.
- MBREQE
Bulk Data Entry Defines a multibody solver output request to output the results of a set of expressions.
- MBREQM
Bulk Data Entry Defines a multibody solver output request to output displacement, velocity, acceleration, or force with respect to markers.
- MBSEQ
Bulk Data Entry Defines the simulation sequence for the multibody solver.
- MBSFRC
Bulk Data Entry Defines a constant scalar load on two grid points.
- MBSFRCC
Bulk Data Entry Defines a curve scalar load on two grid points.
- MBSFRCE
Bulk Data Entry Defines an expression scalar load on two grid points.
- MBSIM
Bulk Data Entry Defines the parameters for a multibody simulation.
- MBSIMP
Bulk Data Entry Defines the simulation parameters for subsequent multibody simulation.
- MBSMNT
Bulk Data Entry Defines a constant scalar moment on two grid points along the specified vector.
- MBSMNTC
Bulk Data Entry Defines a curve scalar moment on two grid points along the specified vector.
- MBSMNTE
Bulk Data Entry Defines an expression scalar moment on two grid points along the specified vector.
- MBVAR
Bulk Data Entry Defines a multibody solver variable which can be referred to by multiple expressions.
- MCELL
Bulk Data Entry Defines the material properties for battery cell material in equivalent circuit modeling.
- MCIRON
Bulk Data Entry Defining the material properties of cast iron material for use in applications involving nonlinear materials.
- MCOHE
Bulk Data Entry Defines the material properties for potential-based cohesive material models.
- MCOHED
Bulk Data Entry Defines the material properties for damage-based cohesive material models.
- MEFFSET
Bulk Data Entry This entry is used to group element sets for which MEFFMASS output is desired in HyperMesh set based format.
- MESHF
Bulk Data Entry Defines options for user-defined input of frequency ranges used to define bands in adaptive meshing for acoustic Adaptive Perfectly Matched Layer (APML) analysis.
- METADATA
Bulk Data Entry METADATA indicates the beginning of metadata content that is to be passed to the OUTPUT2 (.op2 file).
- MFLUID
Bulk Data Entry Used to define properties of a virtual fluid mass. A virtual fluid mass mimics the mass effect of an incompressible inviscid fluid in contact with a structure.
- MGASK
Bulk Data Entry Defining the material properties for gasket-like materials.
- MKAERO1
Bulk Data Entry To input a table of Mach numbers (M) and reduced frequencies (K) for aerodynamic matrix calculation, in unsteady aerodynamic analysis.
- MKAERO2
Bulk Data Entry To input a table of Mach number (M) and reduced frequency (K) pairs for aerodynamic matrix calculation, in unsteady aerodynamic analysis.
- MLOAD
Bulk Data Entry Defines a multibody as a linear combination of load sets defined via GRAV, MBFRC, MBFRCC, MBFRCE, MBMNT, MBMNTC, MBMNTE, MBSFRC, MBSFRCC, MBSFRCE, MBSMNT, MBSMNTC, and MBSMNTE.
- MODCHG
Bulk Data Entry Defines parameters for removing and/or reactivating contact interfaces and/or elements.
- MODOUT
Bulk Data Entry Options for displacement and energy results, based on eigenvectors from PFMODE modal participation.
- MODTRAK
Bulk Data Entry Defines parameters for mode tracking in optimizations with eigenvalue analysis.
- MODULE
Bulk Data Entry Defines a module Bulk Data Entry.
- MOMENT
Bulk Data Entry Defines a static moment at a grid point or a SET of grid points by specifying a vector.
- MOMENT1
Bulk Data Entry Defines a static moment by specification of a value and two grid points, which determines the direction.
- MOMENT2
Bulk Data Entry Defines a static moment by specification of a value and four grid points, which determines the direction.
- MONCARL
Bulk Data Entry Monte-Carlo Simulation control settings for the non-parametric method for variation modeling.
- MONDSP1
Bulk Data Entry Defines a virtual point displacement response at a user-specified reference location. The displacement results are output in the .disp file.
- MONPNT1
Bulk Data Entry Defines an integrated load monitor point at a point (x,y,z) in a user-defined coordinate system. The integrated loads about this point over the associated loads will be computed and printed to the .monpnt file.
- MONPNT2
Bulk Data Entry Define an integrated load monitor point for specific elements and to output results for these elements.
- MONPNT3
Bulk Data Entry Sums select Grid Point Forces to a user chosen monitor point.
- MONSUM
Bulk Data Entry Defines a new monitor result that is the weighted sum of existing monitor results.
- MONSUM1
Bulk Data Entry Defines a new monitor result that is the weighted sum of existing monitor results. The location of the computed MONSUM1 is specified.
- MONSUMT
Bulk Data Entry Defines a new monitor result that is the sum of existing monitor results.
- MONVOL
Bulk Data Entry Defines a one-chamber gas filled structure with hybrid input of inflated gas in explicit dynamic analysis or a cavity filled with fluid in implicit large displacement analysis.
- MOTION
Bulk Data Entry Defines a multibody as a combination of motion sets defined via MOTNJ, MOTNJC, MOTNJE, MOTNG, MOTNGC, and MOTNGE.
- MOTNG
Bulk Data Entry Defines a constant grid point motion.
- MOTNGC
Bulk Data Entry Defines a grid point motion versus time by specifying a curve.
- MOTNGE
Bulk Data Entry Defines a grid point motion through an expression.
- MOTNJ
Bulk Data Entry Defines a constant joint motion.
- MOTNJC
Bulk Data Entry Defines a joint motion versus time by specifying a curve.
- MOTNJE
Bulk Data Entry Defines a joint motion through an expression.
- MOTNJG
Bulk Data Entry Defines motion for joint connector JOINTG Bulk Data Entry.
- MPC
Bulk Data Entry The MPC Bulk Data Entry defines a multipoint constraint equation of the form.
- MPCADD
Bulk Data Entry Defines a multipoint constraint set as a union of multipoint constraint sets defined via MPC entries.
- NLADAPT
Bulk Data Entry Defines parameters for time-stepping and convergence criteria in Nonlinear Analysis.
- NLCTRL
Bulk Data Entry Uses keywords to define various control parameters for both Nonlinear Static and Nonlinear Transient Analysis.
- NLENRG
Bulk Data Entry Defines parameters for energy variables printout for implicit nonlinear static, implicit nonlinear transient analyses, explicit dynamic analysis, and linear static analysis (with Neuber correction).
- NLMON
Bulk Data Entry Defines the settings for runtime monitoring of nonlinear analysis.
- NLOUT
Bulk Data Entry Defines incremental result output parameters for Nonlinear Implicit Analysis (static and transient) and Nonlinear Explicit Analysis.
- NLPARM
Bulk Data Entry Defines parameters for Nonlinear Static Analysis, Nonlinear Transient Analysis, and Nonlinear Heat Transfer Analysis solution control.
- NLPCI
Bulk Data Entry Define the parameters for arc-length method to solve post-buckling problems in nonlinear static analysis.
- NLPRINT
Bulk Data Entry Controls the printing of certain information to the _nl.out file for nonlinear analysis.
- NLRGAP
Bulk Data Entry Defines a nonlinear radial (circular) gap for direct transient response analysis.
- NOLIN1
Bulk Data Entry Defines nonlinear transient forcing functions of the form.
- NOLIN2
- NOLIN3
- NOLIN4
- NSGE
Bulk Data Entry Defines non-structural material damping for a list of elements or properties.
- NSGE1
- NSGEADD
Bulk Data Entry Defines non-structural material damping as the sum of the sets listed.
- NSM
Bulk Data Entry Defines non-structural mass per unit Length, per unit Area, or per unit Volume for a list of elements or properties.
- NSM1
Bulk Data Entry Defines non-structural mass per unit area or per unit length for a list of elements or properties.
- NSMADD
Bulk Data Entry Defines non-structural mass as the sum of the sets listed.
- NSML
Bulk Data Entry Defines lumped non-structural mass for a list of elements or properties.
- NSML1
- PAABSF
Bulk Data Entry Defines the properties of the fluid acoustic absorber element.
- PACABS
Bulk Data Entry Defines the properties of an acoustic absorber element.
- PACINF
Bulk Data Entry Defines the properties of Acoustic Infinite Elements.
- PACPML
Bulk Data Entry Defines the properties of acoustic Adaptive Perfectly Matched Layer (APML) elements.
- PAERO1
Bulk Data Entry Defines properties for lifting panels (CAERO1 panels) and also identifies the slender bodies (CAERO2 panels) associated/interacting with the lifting panels. This is used for Vortex Lattice Method (VLM) and Doublet Lattice Method (DLM) in subsonic aeroelastic analysis and for Constant Pressure Method (CPM) in supersonic aeroelastic analysis.
- PAERO2
Bulk Data Entry Defines the cross-sectional properties of slender bodies. This is used for Vortex Lattice Method (VLM) and Doublet Lattice Method (DLM) in subsonic aeroelastic analysis.
- PAFLUID
Bulk Data Entry Defines the properties of a 1D CAFLUID heat flow element.
- PANEL
Bulk Data Entry Defines up to four sets of grid points or elements as panels for panel participation output for a frequency response analysis of a coupled fluid-structural model.
- PANELG
Bulk Data Entry Defines a set of grid points and/or elements as a generic panel.
- PARAM
Bulk Data Entry Defines values for parameters used during analysis and optimization.
- PAXI
Bulk Data Entry Defines the properties of 2D axisymmetric elements. Referenced by CTAXI and CQAXI entries.
- PAXIG
Bulk Data Entry Defines the properties of general axisymmetric elements. References by the CTAXIG and CQAXIG elements.
- PBAR
Bulk Data Entry Defines the properties of a simple beam (bar), which is used to create bar elements via the CBAR entry.
- PBARL
Bulk Data Entry Defines the properties of a simple beam (bar) by cross-sectional dimensions, which is used to create bar elements via the CBAR entry.
- PBEAM
Bulk Data Entry Defines the properties of beam elements defined via the CBEAM entry.
- PBEAML
Bulk Data Entry Defines the properties of a beam element by cross-sectional dimensions that are used to create beam elements via the CBEAM entry.
- PBEND
Bulk Data Entry Defines the property of curved beam or pipe elements defined via the CBEND entry.
- PBUSH
Bulk Data Entry Defines the nominal property values for a generalized spring-damper-mass structural element.
- PBUSH1D
Bulk Data Entry Defines the linear and nonlinear properties for a one-dimensional spring-and-damper structural element.
- PBUSHFX
Bulk Data Entry Defines the various nominal property values for a generalized spring-damper-mass structural element. This property is not affected by translational and rotational stiffness limits specified using PARAM, BUSHSTIF.
- PBUSHT
Bulk Data Entry Defines property values for a generalized spring and damper structural element.
- PCELL
Bulk Data Entry Defining the properties for battery cell elements.
- PCOHE
Bulk Data Entry Defines the properties for cohesive elements.
- PCOMP
Bulk Data Entry Defines the structure and properties of an n-ply composite laminate material.
- PCOMPG
Bulk Data Entry Defines the structure and properties of a composite laminate material, allowing for global ply identification.
- PCOMPLS
Bulk Data Entry Defines global ply-based composite properties for continuum shell composites.
- PCOMPP
Bulk Data Entry Defines the properties of a composite laminate material used in ply-based composite definition.
- PCONT
Bulk Data Entry Defines properties of a CONTACT interface.
- PCONTEC
Bulk Data Entry Defines Contact Electric Conductance Coefficient (CECC) for CONTACT elements in electrical analysis.
- PCONTES
Bulk Data Entry Defines Contact Permittance Coefficient (CPC) for CONTACT elements, in electrostatic analysis and piezoelectric analysis.
- PCONTHT
Bulk Data Entry Defines conductance for CONTACT elements in heat transfer analysis.
- PCONV
Bulk Data Entry Defines a free convection boundary condition properties.
- PCONVLIB
Bulk Data Entry Defines the external function to be called to calculate time and temperature-dependent free-convection coefficient in a convection element.
- PDAMP
Bulk Data Entry Specifies the damping of a scalar damper element using defined CDAMP1 or CDAMP3 entry.
- PEAKOUT
Bulk Data Entry Defines criteria used for the automatic identification of loading frequencies at which result peaks occur. Other result output may then be requested at these "peak" loading frequencies. This feature is only supported for frequency response solution sequences.
- PELAS
Bulk Data Entry Used to define the stiffness and stress coefficient of a scalar elastic element (spring) by means of the CELAS1 or CELAS3 entry.
- PELASFX
- PELAST
Bulk Data Entry Defines the frequency dependent property values for a PELAS Bulk Data Entry. It can also be used to define a nonlinear spring for Nonlinear Analysis via the TKNID field.
- PERBC
Bulk Data Entry Defines a connection between opposite edges/faces of the structure. This entry is used to apply Periodic Boundary Conditions to the model.
- PFAST
Bulk Data Entry Define properties of connector (CFAST) elements.
- PFASTG
Bulk Data Entry Defines properties for Fastener Element Connection specified by a CFASTG entry.
- PFAT
Bulk Data Entry Defines element properties for fatigue analysis.
- PFATSDR
Bulk Data Entry Defines properties for solder fatigue analysis.
- PFATSMW
Bulk Data Entry Defines properties for Seam Weld Fatigue Analysis.
- PFATSPW
Bulk Data Entry Defines properties for Spot Weld Fatigue Analysis.
- PFPATH
Bulk Data Entry Defines a one-step transfer path analysis.
- PFBODY
Bulk Data Entry Defines a flexible body out of a list of finite element properties, elements, and grid points.
- PGAP
Bulk Data Entry Defines properties of the gap (CGAP or CGAPG) elements.
- PGAPEC
Bulk Data Entry Defines electrical conductance properties for the gap elements (CGAP or CGAPG) in electrical analysis.
- PGAPES
Bulk Data Entry Defines electrical permittance properties for the gap elements (CGAP or CGAPG) in electrostatic analysis and piezoelectric analysis.
- PGAPHT
Bulk Data Entry Defines heat transfer conduction properties of the gap (CGAP or CGAPG) elements for heat transfer analysis.
- PGASK
Bulk Data Entry Defining the properties for solid gasket elements.
- PHFSHL
Bulk Data Entry Defines the thickness, material, blank holder, binder and Forming Limit Curve references for a shell property in a one-step stamping simulation.
- PJOINTG
Bulk Data Entry Defines the properties for a joint connection between two grids via the JOINTG Bulk Data Entry.
- PLASTIC
Bulk Data Entry Can be used to describe elasto-plastic material behavior (currently supported for MAT1).
- PLOAD
Bulk Data Entry Defines a static pressure load on a triangular or quadrilateral element. It can also be used to define the EXCITEID field (Amplitude "A") of dynamic loads in RLOAD1, RLOAD2, TLOAD1 and TLOAD2 Bulk Data Entries.
- PLOAD1
Bulk Data Entry Defines concentrated, uniformly distributed, or linearly distributed applied loads to the CBAR or CBEAM elements or a SET of such elements at user-chosen points along the axis.
- PLOAD2
Bulk Data Entry Defines a uniform static pressure load applied to two-dimensional elements, or a SET of such elements.
- PLOAD4
Bulk Data Entry Defines a load on a face of a HEXA, PENTA, TETRA, PYRA, TRIA3, TRIA6, QUAD4, or QUAD8 element.
- PLOADE1
Bulk Data Entry Defines an in-plane surface traction on the edge of CTPSTN, CQPSTN, CTPSTS, and CQPSTS elements.
- PLOADSF
Bulk Data Entry Parameters of pressure loads on a surface defined by a SURF Bulk Data Entry or SET Bulk Data Entry.
- PLOADX1
Bulk Data Entry Defines a static surface traction on the CQAXI, CTAXI, CTRIAX6, CQAXIG and CTAXIG axisymmetric elements. The PLOADX1 entry can be defined as follower loads in Large Displacement Nonlinear Analysis.
- PLOADXG
Bulk Data Entry Defines a surface traction on the general axisymmetric elements CQAXIG and CTAXIG.
- PLOTEL
Bulk Data Entry Defines a one-dimensional dummy element for use in plotting.
- PLOTEL3
Bulk Data Entry Defines a three-noded, two-dimensional dummy element for use in plotting.
- PLOTEL4
Bulk Data Entry Defines a four-noded, two-dimensional dummy element for use in plotting.
- PLSOLID
Bulk Data Entry Defines the properties of nonlinear hyperelastic solid elements, referenced by CHEXA, CPENTA, and CTETRA Bulk Data Entries. The MATHE hyperelastic material can be referenced to define corresponding material properties.
- PLY
Bulk Data Entry Defines the properties of a ply used in ply-based composite definition.
- PMASS
Bulk Data Entry Defines the mass value of a scalar mass element (CMASS1 or CMASS3 entry).
- PPLANE
Bulk Data Entry Defines the properties of plane stress and plane strain elements (CTPSTN, CQPSTN, CTPSTS, and CQPSTS).
- PRBODY
Bulk Data Entry Defines a rigid body out of a list of finite element properties, elements and grid points.
- PRETENS
Bulk Data Entry Defines 1D or 3D pre-tensioned bolt section.
- PRETPRM
Bulk Data Entry Defines parameters that control initial loading conditions on pretension sections for 1D and 3D bolt pre-tensioning. These parameters also control the printing of diagnostic information about pretension sections.
- PROD
Bulk Data Entry Defines the properties of a rod, which is referenced by the CROD entry.
- PRSPENE
Bulk Data Entry Defines a pressure penetration load which can simulate fluid penetrating through the surfaces on a contact interface.
- PSEAM
Bulk Data Entry Define properties of connector (CSEAM) elements.
- PSEC
Bulk Data Entry Defines property information for planar section elements used in the definition of arbitrary beam cross-sections.
- PSHEAR
Bulk Data Entry Defines the properties of a shear panel.
- PSHELL
Bulk Data Entry Defines the membrane, bending, transverse shear, and membrane-bending coupling of shell elements.
- PSOLID
Bulk Data Entry Defines the properties of solid elements, referenced by CHEXA, CPENTA, CPYRA and CTETRA Bulk Data Entries.
- PSURF
Bulk Data Entry Defines properties of a contact surface.
- PTADD
Bulk Data Entry Defines a pretension load as a linear combination of load sets defined via PTFORCE, PTFORC1, PTADJST and PTADJS1 entries.
- PTADJS1
Bulk Data Entry Defines adjustment (additional shortening) on a set of pretension sections.
- PTADJST
Bulk Data Entry Defines the adjustment (shortening) on a pretension section.
- PTFORCE
Bulk Data Entry Defines pretensioning force on pretension section.
- PTFORC1
Bulk Data Entry Defines pretensioning force on a set of pretension sections.
- PTUBE
Bulk Data Entry Defines the properties of a thin-walled cylindrical tube element, referenced by a CTUBE entry.
- PVISC
Bulk Data Entry Defines properties of a one-dimensional viscous damping element (CVISC entry).
- PWELD
Bulk Data Entry Defines properties of connector (CWELD) elements.
- QBDY1
Bulk Data Entry Defines a uniform heat flux for CHBDYE elements.
- QBDYLIB
Bulk Data Entry Defines the external function to be called to calculate time and temperature-dependent Uniform Heat Flux values.
- QVOL
Bulk Data Entry Defines a rate of volumetric heat addition in a conduction element.
- QVOLLIB
Bulk Data Entry Defines the external function called to calculate time and temperature-dependent rate of volumetric heat addition in a conduction element.
- RADADD
Bulk Data Entry Defines a combination of multiple RADSND cards to be solved within one subcase.
- RADBC
Bulk Data Entry Defines the radiation boundary conditions and identifies CHBDYE entries for heat transfer analysis via radiation.
- RADM
Bulk Data Entry Defines the radiation material properties of a surface element for heat transfer analysis.
- RADSND
Bulk Data Entry Defines a set of grid points where the sound will be calculated as well as the panels that are generating the sound.
- RANDPS
Bulk Data Entry Defines load set power spectral density factors for use in random analysis having the frequency dependent form
- RANDT1
Bulk Data Entry Defines time lag constants for use in random analysis autocorrelation function computation.
- RBADD
Bulk Data Entry Defines a rigid body as a combination of Rigid Bodies (RBODY).
- RBAR
Bulk Data Entry Defines a rigid bar with six degrees-of-freedom at each end.
- RBE1
Bulk Data Entry Defines a rigid body connected to an arbitrary number of grid points.
- RBE2
Bulk Data Entry Defines a rigid body whose independent degrees-of-freedom are specified at a single grid point and whose dependent degrees-of-freedom are specified at an arbitrary number of grid points.
- RBE2GS
Bulk Data Entry Defines a rigid element connecting two grid points which are closest to the grid point referenced by the field GS.
- RBE3
Bulk Data Entry Defines the motion at a "reference" grid point as the weighted average of the motions at a set of other grid points.
- RBODY
Bulk Data Entry Defines a rigid body as a set of elements, grid points.
- RCROSS
Bulk Data Entry Defines a pair of response quantities for computing the cross-power spectral density functions in random response analysis.
- RELOC
Bulk Data Entry Geometrically maps parts (for example, elements and grids) from one location to another. This entry allows you to define mapping as MOVE (translation), ROTATE, MIRROR, or MATCH (as an arbitrary transformation which matches grids from one group to similar grids in another group).
- RFORCE
Bulk Data Entry Defines a static loading condition due to a centrifugal force field. It can also be used to define the EXCITEID field (Amplitude "A") of dynamic loads in RLOAD1, RLOAD2 , TLOAD1 and TLOAD2 Bulk Data Entries.
- RGYRO
Bulk Data Entry Includes data required to perform Rotor Dynamics analysis in Modal Frequency Response Analysis and/or Modal Complex Eigenvalue Analysis. The RGYRO Bulk Data Entry is referenced by a corresponding RGYRO Subcase Information Entry in a specific subcase.
- RJOINT
Bulk Data Entry Defines a Rigid Joint connection at two coincident grids.
- RLOAD1
Bulk Data Entry Defines a frequency-dependent dynamic load of the form:
for use in frequency response problems.
- RLOAD2
- ROTOR
Bulk Data Entry 3D Rotor Definition. Specifies list of sets, elements or properties that comprise the rotor 3D model.
- ROTORG
Bulk Data Entry 1D rotor definition. Specifies grids that determine the Rotor Line model.
- RROD
Bulk Data Entry Defines a pin-ended rod that is rigid in extension.
- RSPEC
Bulk Data Entry Specifies directional combination method, modal combination method, excitation direction(s), response spectra and scale factors for Response Spectrum Analysis.
- RSPEED
Bulk Data Entry Specifies a set of reference rotor speed values for asynchronous analysis in Rotor Dynamics.
- RSPINR
Bulk Data Entry Defines the relative spin rates between rotors and rotor damping parameters during a rotor dynamic analysis in Static, Modal Complex Eigenvalue or Frequency Response solution sequences.
- RSPINT
Bulk Data Entry Defines the rotor spin rates and rotor damping parameters with respect to time during a Transient Rotor Dynamics Analysis.
- RSPLINE
Bulk Data Entry Defines multi-point constraints for the interpolation of displacements at grid points.
- RSSCON
Bulk Data Entry Defines multi-point constraints to model clamped connections of shell-to-solid elements.
- RSSCON1
Bulk Data Entry Defines a set of constraints for shell-to-solid connection on surfaces.
- RSURF
Bulk Data Entry Defines a rigid analytical surface for explicit analysis.
- RVDOF
Bulk Data Entry Defines the degrees of freedom where the residual vectors are to be calculated.
- RVDOF1
- SEBULK
Bulk Data Entry Defines superelement boundary search options and the type of superelement.
- SECONCT
Bulk Data Entry Defines grid and scalar point connection procedures for a partitioned superelement.
- SECSET
Bulk Data Entry Defines free boundary degrees-of-freedom for One-Step Superelement Analysis.
- SECSET1
Bulk Data Entry Defines free boundary degrees-of-freedom to be free for use in One-Step Superelement Analysis (Alternate Format).
- SECTION
Bulk Data Entry Defines a user-defined cross-section based on a specific face of the model.
- SELOC
Bulk Data Entry Defines a partitioned superelement relocation by listing three noncolinear grids in the superelement and three corresponding grids not belonging to the superelement.
- SENSOR
Bulk Data Entry Sensors may be used to activate loads.
- SENSRAD
Bulk Data Entry Defines a union of several SENSOR entries.
- SEQSET
Bulk Data Entry Defines the generalized degrees-of-freedom of the superelement for use in One-Step Superelement Analysis.
- SEQSET1
Bulk Data Entry Defines the generalized degrees-of-freedom of the superelement for use in One-Step Superelement Analysis (Alternate Format).
- SESET
Bulk Data Entry Defines the interior grid points for One-Step Superelement Analysis.
- SET
Bulk Data Entry Defines a set of grids, elements, design variables, MBD entities, mode numbers, frequencies or times for reference by other input definitions.
- SET1
Bulk Data Entry Defines a list of structural grid points or element identification numbers.
- SET3
Bulk Data Entry Defines a set of grids or elements.
- SETREE
Bulk Data Entry Defines the Superelement Tree for One-Step Superelement Analysis.
- SLOAD
Bulk Data Entry Defines concentrated static loads on scalar, grid or fluid points.
- SOLVTYP
Bulk Data Entry Defines the solver type to be used for static and dynamic analysis.
- SPC
Bulk Data Entry This entry can be used to define single-point constraints and enforced displacements for structural Analysis.
- SPC1
Bulk Data Entry Defines sets of single-point constraints and thermal boundary conditions.
- SPCADD
Bulk Data Entry Defines a single-point constraint set as a union of single-point constraint sets defined via SPC or SPC1 entries.
- SPCD
Bulk Data Entry This entry can be used to define enforced displacement value for Static Analysis.
- SPCDLIB
Bulk Data Entry Defines the external function to be called to calculate time and temperature-dependent SPCD temperature values.
- SPCF
Bulk Data Entry Used to apply SPC Force at a grid point or a SET of grid points in a continuing subcase of implicit nonlinear analysis.
- SPCOFF
Bulk Data Entry Defines degrees-of-freedom to be excluded from AUTOSPC.
- SPCOFF1
- SPCP
Bulk Data Entry Defines the flow pressure boundary conditions for Darcy Flow Analysis.
- SPLINE1
Bulk Data Entry Defines a surface spline for interpolating motion and forces for aeroelastic problems on aerodynamic geometries defined by regular arrays of aerodynamic points.
- SPLINE2
Bulk Data Entry Defines a beam spline for interpolating motion and/or forces for aeroelastic problems on aerodynamic geometries defined by regular arrays of aerodynamic points.
- SPLINE4
Bulk Data Entry Defines a curved surface spline for interpolating motion and forces for aeroelastic problems on aerodynamic geometries.
- SPOINT
Bulk Data Entry Defines scalar points.
- STACK
Bulk Data Entry Defines the stacking information and stacking sequence for ply-based composite definition.
- STEADY
Bulk Data Entry Defines the combination of frequency response and linear static subcases used for steady state analysis.
- SUPORT
Bulk Data Entry Defines determinate reaction degrees-of-freedom in a free body.
- SUPORT1
- SURF
Bulk Data Entry Defines a face of a shell or solid (3D solid, axisymmetric solid, or plane-strain solid) element as part of a surface.
- SWLDPRM
Bulk Data Entry Defines values of parameters used during the CWELD and CSEAM connectivity search.
- TABDMP1
Bulk Data Entry Defines modal damping as a tabular function of natural frequency.
- TABDMP2
Bulk Data Entry Defines modal damping as a tabular function of mode index.
- TABFAT
Bulk Data Entry Defines y values of each point on the loading time history.
- TABLED1
Bulk Data Entry Defines a tabular function for use in generating frequency-dependent and time-dependent dynamic loads.
- TABLED2
Bulk Data Entry Defines a tabular function for use in generating frequency-dependent and time-dependent dynamic loads. Also contains parametric data for use with the table.
- TABLED3
- TABLED4
Bulk Data Entry Defines the coefficients of a power series for use in generating frequency-dependent and time-dependent dynamic loads. Also contains parametric data for use with the table.
- TABLEG
Bulk Data Entry Defines a general tabular function for use in supported reference entries.
- TABLEM1
Bulk Data Entry Defines a tabular function for use in generating temperature-dependent material properties.
- TABLEM2
Bulk Data Entry Defines a tabular function for use in generating temperature-dependent material properties. Also contains parametric data for use with the table.
- TABLEM3
- TABLEM4
Bulk Data Entry Defines coefficients of a power series for use in generating temperature-dependent material properties. Also contains parametric data for use with the table.
- TABLEMD
Bulk Data Entry Defines a multi-dimensional tabular function which identifies single or multiple X-values for a single Y-value.
- TABLES1
Bulk Data Entry Defines a tabular function for material and friction property.
- TABLEST
Bulk Data Entry Specifies the material property tables for elasto-plastic, temperature-dependent materials.
- TABRND1
Bulk Data Entry Defines power spectral density as a tabular function of frequency for use in random analysis. Referenced on the RANDPS entry.
- TEMP
Bulk Data Entry Defines temperature at grid points or a SET of grid points for determination of thermal loading and stress recovery.
- TEMPADD
Bulk Data Entry Defines a temperature set as a union of temperature sets defined via the TEMP or TEMPD Bulk Data Entries.
- TEMPD
Bulk Data Entry Defines a temperature value for all grid points of the structural model that have not been given a temperature on a TEMP entry.
- TEMPP1
Bulk Data Entry Defines temperature field for shell elements (as a combination of reference plane temperature and linear thermal gradient through thickness) for determination of thermal loading, temperature-dependent material properties and stress recovery.
- TEMPSEC
Bulk Data Entry Defines temperature at grid points or a SET of grid points for determination of thermal loading on shell elements through thickness direction.
- TEMPT
Bulk Data Entry Defines parameters for mapping the grid temperature field from either an external file or an internal heat transfer subcase to either Nonlinear Static Analysis or Nonlinear Transient Analysis. The mapping is over time-domain only.
- THIST
Bulk Data Entry Defines the time history output request for Nonlinear Explicit Analysis.
- TIC
Bulk Data Entry Defines values for the initial conditions of variables used in Structural Transient Analysis and Explicit Analysis. Both displacement and velocity values may be specified at independent degrees-of-freedom.
- TICA
Bulk Data Entry Defines the initial velocity on a set of grids along and about an axis.
- TIE
Bulk Data Entry Defines a tied contact.
- TLOAD1
Bulk Data Entry Defines a time-dependent dynamic load or enforced motion.
- TLOAD2
Bulk Data Entry Defines a time-dependent dynamic excitation or enforced motion.
- TRIM
Bulk Data Entry Specifies the constraints for aeroelastic trim variables.
- TSTEP
Bulk Data Entry Defines time step parameters for control and intervals at which a solution will be generated and output in transient analysis.
- TSTEPNL
Bulk Data Entry Defines parameters for Nonlinear Direct Transient Analysis.
- TSTEPE
Bulk Data Entry Defines time step parameters for control and intervals at which a solution will be generated and output in explicit analysis.
- UNBALNC
Bulk Data Entry Defines the unbalanced rotating load during a rotor dynamic analysis in Modal Frequency Response, Linear Direct Transient or Small Displacement Nonlinear Direct Transient solution sequences. The unbalanced load is specified in a cylindrical system where the rotor rotation axis is the Z-axis.
- USET
Bulk Data Entry Defines a set of degrees-of-freedom.
- USET1
- VISCO
Bulk Data Entry Defines parameters for nonlinear analysis involving time-dependent material behavior.
