MBREQE
Bulk Data Entry Defines a multibody solver output request to output the results of a set of expressions.
MBREQE RSID RID E1 E2 E3 E4 E5 E6
MBREQE 235 10 20 30 40
RSID Request set identification number.
(Integer > 0)
RID Request identification number. Request ID must be unique with respect to all other MBREQM and MBREQE cards.
(Integer > 0)
E1 ID of MBVAR.
(Integer > 0)
E2, … E6 Additional MBVAR IDs.
Default = blank (blank or Integer > 0)
  1. The request evaluates the expression at every output step.
  2. The values are always set to 0, if the expression is not specified.
  3. Request set will be specified in the subcase definition.
