ACCEL2
Bulk Data Entry Defines static acceleration loads at a specific SET of GRID points in the model. Additionally, scale factors for varying direction acceleration loads can be defined using tabular data.
ACCEL2 | SID | SSID | CID | A | N1 | N2 | N3 | ||
DIR | TID |
ACCEL2 | 100 | 4 | 0 | 2.0 | 1.0 | 3.0 | 5.0 | ||
X | 11 |
Definition
SID | Acceleration load set
identification number. (Integer > 0) |
SSID | Identification for a SET
of Grid points at which the acceleration load is applied.
(Integer > 0 or <String>) |
CID | Coordinate system
(Integer ≥ 0, or blank) |
A | Scale factor for the
acceleration load vector. Default = blank (Real, if non-zero loading is required, then A should be non-zero) |
N1,N2,N3 | Acceleration load vector
components in the coordinate system
CID. Default = blank (Real, if non-zero loading is required, then a minimum of one Ni should be non-zero) |
DIR | Component direction of the
acceleration load variation. Default = blank (Character; one of X, Y, or Z) |
TID | Identification number of a
TABLED1 entry that specifies the Location
(LOCi) versus Scale Factor
(VALi) values (similar to the
ACCEL entry). Default = blank (Integer > 0) |
- The acceleration load applied to all grid
points in the referenced SSID SET in the model is given
by:
- Acceleration load.
- Vector with components N1, N2, and N3.
- Directional varying scale factor which is defined based on DIR and TID fields. This is not mandatory and if DIR and TID are both blank.
- Is applied and a constant acceleration load is applied for the whole model.
Figure 1. Acceleration Load Factor (VAL) versus Location along DIR (LOC)
- The acceleration loads specified in the ACCEL2 entry can be combined with other loads, such as FORCE, MOMENT, GRAV, ACCEL, and ACCEL1, through the LOAD Subcase Information Entry. The SID on the ACCEL entry should be unique with regard to any other load entry.
- The acceleration load does not include effects, due to mass on SPOINTs.
- The ACCEL2 entry is similar to the ACCEL entry. The ACCEL load is applied to the entire model while the ACCEL2 load is calculated similar to ACCEL but applied only to the specified SET of grid points (SSID). Additionally, an extra scale factor A is applied to the acceleration load vector.
- String based labels allow for easier visual identification of sets, including when being referenced by other cards. For more details, refer to String Label Based Input File in the Bulk Data Input File.
- This card is represented as a force load in HyperMesh.
