CACPML3
Bulk Data Entry Defines an acoustic Adaptive Perfectly Matched Layer (APML) element with a triangular base.
CACPML3 EID PID G1 G2 G3
CACPML3 7 1 123 225 9991
EID Unique element identification number.
No default (Integer > 0)
PID PACPML property entry identification number.
G1, G2, G3 Grid point identification numbers of element base connection points.
  1. This element should be connected to acoustic grid points. These elements form the surface of the APML layer on top of an acoustic domain.
  2. A 4-noded formulation of this element, CACPML4 is also available.
  3. For more information, refer to Adaptive Perfectly Matched Layer Method for Exterior Acoustics in the User Guide.
