RVDOF
Bulk Data Entry Defines the degrees of freedom where the residual vectors are to be calculated.
| RVDOF | G1 | C1 | G2 | C2 | G3 | C3 | G4 | C4 |
| RVDOF | 564 | 4 | 765 | 4561 |
| Gi | Grid or scalar point
identification numbers. No default (Integer > 0) |
| Ci | Component
numbers. Integer zero or blank for scalar points, or up to 6 unique digits (0 < integer ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points. |
