Bulk Data Entry Defines a set of frequencies to be used in the solution
of frequency response problems.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
FREQ |
SID |
F1 |
F2 |
F3 |
F4 |
F5 |
F6 |
F7 |
F8 |
etc |
etc |
etc |
etc |
etc |
etc |
etc |
Alternate Format
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
FREQ |
SID |
F1 |
F2 |
F3 |
F4 |
etc |
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
FREQ |
3 |
7.0 |
12.56 |
13.99 |
23.4 |
23.34 |
Example (Alternate Format)
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
FREQ |
3 |
7.0 |
12.56 |
13.99 |
23.4 |
Field |
Contents |
SI Unit Example |
SID |
Identification
number. No default (Integer > 0)
F# |
Frequency value. The
units for F# are cycles per unit time. No
default (Real ≥ 0.0)
- FREQ entries must be
selected with the I/O Options or Subcase Information command FREQUENCY = SID.
- All FREQi entries
with the same set identification numbers will be used. Duplicate frequencies
will be ignored.
and
are considered duplicated if: (1)
Where,
- DFREQ
- User parameter with a default of 10-5 *
- The maximum and minimum excitation frequencies of the combined
FREQi entries
- This card is represented as a load
collector in HyperMesh.
