SPCOFF
Bulk Data Entry Defines degrees-of-freedom to be excluded from AUTOSPC.
SPCOFF G1 C1 G2 C2 G3 C3 G4 C4
SPCOFF 13 234 14 5
Definition
Gi Grid or scalar point identification number.
(Integer > 0)
C Component numbers.
(Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points).
  1. Degrees-of-freedom on this entry will be excluded from AUTOSPC.
  2. If both SPC and SPCOFF are defined for the same degree-of-freedom, then SPC takes priority
