CHARGE
Bulk Data Entry Defines a point electric charge at a grid or a set of grids.
CHARGE SID GID/GSETID VALUE
GSET
CHARGE 2 5 2.3
SID Load identification number
No default (Integer > 0)
GID/GSETID
GID
Grid or scalar point identification number
GSETID
Identification number of a SET of grid points. In this case, the GSET continuation line must be specified.
VALUE The magnitude of the point electric charge
No default (Real)
GSET Flag to indicate that the GID/GSETID field is identified as a SET of grid points at which the charge is applied.
  1. For more information, refer to Piezoelectric Analysis in the User Guide.
