MONPNT2
Bulk Data Entry Define an integrated load monitor point for specific elements and to output results for these elements.
MONPNT2 | NAME | LABEL | |||||||
TABLE | TYPE | NDDLitem | EID |
MONPNT2 | PART12 | Stringer load | |||||||
STRESS | CBAR | SX2A | 101 |
Definition
NAME | Unique character string identifier for the monitor point. No default (Character) |
LABEL | A character string that identifies and labels the monitor point.
Up to 56 characters are supported. Default = blank (Character) |
TABLE | Type of the output to be monitored. 2
TYPE | Type of the element to be monitored. No default (Character) |
NDDLitem | Item code for the element type to be monitored. List of supported elements and their codes can be found in the NDDL item code table. No default (Character) |
EID | ID of the element to be monitored. No default (Integer > 0) |
- The MONPNT2 entry is supported only for linear static and static aeroelastic analysis.
- If invalid entities are specified in TABLE, TYPE, NDDLitems or EID fields, an error message will be issued.
- The results requested by the MONPNT2 entry will be printed to the .monpnt file.
