QBDY1
Bulk Data Entry Defines a uniform heat flux for CHBDYE elements.
QBDY1 SID Q0 EID1 EID2 EID3 EID4 EID5 EID6
Alternate Format
QBDY1 SID Q0 EID1 "THRU" EID2
SID Load set identification number.
No default (Integer > 0)
Q0 Heat flux into element. Is positive for heat input.
No default (Real)
EID# CHBDYE surface element identification numbers. With alternate format using "THRU" EID2 > EID1.
No default (Integer ≠ 0)
  1. QBDY1 entries must be selected with the Case Control command LOAD=SID in order to be used in static analysis. The total power into an element is given by the equation:
    P i n = ( Effective _ Area ) * Q 0
  2. This card is represented as a flux load in HyperMesh.
