MOTNJC
Bulk Data Entry Defines a joint motion versus time by specifying a curve.
| MOTNJC | SID | JID | MTYPE | CVID | INT | EID | DTYPE | ||
| D0 | V0 |
| MOTNJC | 3 | 345 | ROT | 2 | AKIMA | 99 |
| SID | Load set identification
                                    number. (Integer > 0)  |
| JID | Grid point identification
| MTYPE | TRANS or ROT, ignored for revolute and translational joints. | |
| CVID | Set identification number
                                of the MBCRV entry that gives the motion versus
                                    time. (Integer > 0)  |
| INT | Interpolation type.
 (Character)  |
| EID | Set identification number
                                of the MBVAR for the
                                independent variable expression. Default = TIME (Integer ≥ 0 or blank)  |
| DTYPE | Motion data type.
| D0 | Initial displacement, if motion data is of type velocity or acceleration, ignored otherwise. | |
| V0 | Initial velocity, if motion data type is acceleration, ignored otherwise. |
- Joint motion can only be applied to cylindrical joints (MTYPE = TRANS or ROT), revolute joints (MTYPE = ROT), and translational joints (MTYPE = TRANS).
 - The MOTNJC Bulk Data Entry should be selected in the MOTION Subcase Information section, if it is to be included in the analysis.
