MONSUMT
Bulk Data Entry Defines a new monitor result that is the sum of existing monitor results.
The existing monitor points do not need to be the same type but must be of a similar type. The results are printed to the .monpnt file.
MONSUMT NAME LABEL
AXIS CP X Y Z CD
MTYPE1 NAME1a NAME1b NAME1c NAME1d NAME1e NAME1f NAME1g
MTYPE1 NAME2a NAME2b NAME2c NAME2d NAME2e NAME2f NAME2g
Example: Create new monitor point by adding aerodynamic MONPNT1 and MONPNT3
MONSUMT ROFS_900 FUSELAGE STATION 900
123456 500 0.0 25.0 20
MONPNT3 FS_1000 FS_1100 FS_1200 FS_1300 MONPNT3
AMONPNT1 HTP_ROOT AMONPNT1
NAME Character string identifying the monitor point.
No default (Character, a maximum of 8 characters)
LABEL A character string that identifies and labels the monitor point.
Default = blank (Character, a maximum of 56 characters, fields 3 through 9)
AXIS The component axis of the newly created monitor point into which the summed quantity is stored.
(Integer > 0, up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks)
CP The identification number of a coordinate system in which the input (X,Y,Z) coordinates are defined.
Default = 0 (Integer > 0)
X, Y, Z The coordinates in the CP coordinate system about which the loads are monitored.
Default = 0.0 (Real)
CD The identification number of a coordinate system in which the resulting load components are output.
Default = Coordinate system specified by the CP field (Integer > 0)
MTYPEij Monitor type to be merged.
No default (AMONONT1, SMONONT1, MONPNT3)
NAMEij Name of the monitored quantity that is summed.
  1. The LABEL is a 56 character string that should be unique.
  2. The result of the MONSUMT entry is to create new monitor point(s) as:
    MONSUM T j = i n T ij M R i MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeWabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGnbGaam4taiaad6eacaWGtbGaam yvaiaad2eacaWGubWaaSbaaSqaaiaadQgaaeqaaOGaaGPaVlabg2da 9iaaykW7daaeWbqaaiaadsfadaWgaaWcbaGaamyAaiaadQgaaeqaaO GaamytaiaadkfadaWgaaWcbaGaamyAaaqabaaabaGaamyAaaqaaiaa d6gaa0GaeyyeIuoaaaa@469C@
    Where,
    M R i MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeWabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGnbGaamOuamaaBaaaleaacaWGPb aabeaaaaa@3481@
    Result from the monitor points being summed.
    T ij MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeWabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGubWaaSbaaSqaaiaadMgacaWGQb aabeaaaaa@34A0@
    Set of partial rigid body vectors for the locations of the monitor points being summed, with the origin at the X, Y, Z location.
  3. The merged monitor points must be of a similar type. "Similar" types are defined as force and moment summation monitor points: AMONPNT1, SMONPNT1, MONPNT3.
  4. For MONPNT1s, the MTYPij can be aerodynamic or structural. MTYPij=AMONPNT1 designates aerodynamic, while SMONPNT1 designates a structural monitor point.
  5. If multiple types are specified on a MONSUMT, the resulting entry is of a type that appears on the MONSUMT with the following order of precedence: SMONPNT1 (structural MONPNT1), MONPNT3, AMONPNT1 (aerodynamic MONPNT1). For example, an AMONPNT1 (aerodynamic MONPNT1) and a MONPNT3 appearing on the same entry results in a MONPNT3 regardless of which appears first. If the NEWAXISj field indicates a single output, the AXISij fields must reference a single input, but it can be any value from 1 to 6. There may be as many as 6 AXISij and COEFij for each referenced NAMEij.
