DTI,UNITS
Bulk Data Entry Defines units for multibody, component mode synthesis (flexible-body preparation), and Explicit Dynamic Analysis sequences.
DTI UNITS 1 MASS FORCE LENGTH TIME
DTI UNITS 1 KG N M S
MASS Units of mass. 3
kg (Default)
kilogram
lbm
pound-mass
slug
slug
gram
gram
ozm
ounce-mass
klbm
kilo pound-mass (1000.lbm)
mgg
megagram
slinch
12 slugs
ug
Microgram
ng
Nanogram
uston
US ton
mg
Milligram
FORCE Units of force. 3
n (Default)
newton
lbf
pounds-force
kgf
kilograms-force
ozf
ounce-force
dyne
dyne
kn
kilonewton
klbf
kilo pound-force (1000.lbf)
mn
Millinewton
un
Micronewton
nn
Nanonewton
LENGTH Units of length. 3
mm (Default)
millimeter
km
kilometer
m
meter
cm
centimeter
mi
mile
ft
foot
in
inch
um
Micrometer
nm
Nanometer
ang
Angstrom
yd
yard
mil
Milli-inch
uin
Micro-inch
TIME Units of time. 3
s (Default)
seconds
h
hours
min
minutes
ms
milliseconds
us
Microsecond
nanosec
Nanosecond
d
day
  1. PARAM, WTMASS is ignored for the multibody and component mode synthesis (flexible-body preparation) solution sequences. Unit data for these solution sequences is supplied on the DTI,UNITS Bulk Data Entry.
  2. This DTI, UNITS Data Entry is the same as the UNITS entry.
  3. If the units defined on the DTI,UNITS entry are not consistent, mass unit is ignored, only force, length, and time units are considered in Explicit Dynamic Analysis subcases.
  4. This card is represented as a control card in HyperMesh.
