NLMON
Bulk Data Entry Defines the settings for runtime monitoring of nonlinear analysis.
NLMON | ID | PARAM1 | VALUE1 | PARAM2 | VALUE2 | PARAM3 | VALUE3 | ||
PARAM4 | VALUE4 | PARAM5 | VALUE5 | PARAM6 | VALUE6 |
NLMON | 23 | DISP | ITER | GRID | 4 | DOF | 1 |
MID | Nonlinear Monitoring Entry
ID. No default (Integer > 0) |
DISP | Controls the output of
displacement results in the _nl.h3d file. The
_nl.h3d file is output on-the-fly to help
with monitoring of Nonlinear Analysis runs. 1 The value of this parameter determines the
output intervals.
No default (String) |
GRID | Grid point identification
number for which the displacement results are being monitored in the
.monitor and
_ld.monitor files. No default (Integer > 0) |
DOF | Degree of freedom of the
Grid point specified via the GRID parameter on
this entry. The displacement value is output in the Global
Coordinate system. The Global Coordinate system in OptiStruct is a collection of all local
coordinate systems in the model (CD on
GRID entry). No default (Integer > 0) |
OVERWRITE | Controls how the results
are written to the _nl.h3d file.
- NLMON entry controls the
following results.
- Nonlinear runtime results monitoring via the _nl.h3d file, and additionally convergence table information for the specified intervals which is output to the _nl.out file (and visualized via the os_out_file_parser.tcl script in HyperView). For more information, refer to Runtime Monitoring.
- The _nl.h3d file, in addition, this also contains Grid Sets identifying contact status changes and element sets which identify distorted elements. The _nl.out file contains a summary of the contact change grids and distorted elements, and the corresponding printing can be controlled via the NLPRINT Bulk/Subcase pair.
- NLMON also allows you to identify a particular GRID and DOF for corresponding incremental output in .monitor and _ld.monitor files. If the GRID and DOF parameters are not specified, the corresponding maximum translational displacement among all grids (only magnitude), and the corresponding DOF is output to those files.
- The <filename>.monitor and <filename>_ld.monitor files are output by default for any nonlinear analysis; however, the displacement results for a particular DOF are output only if the NLMON Bulk Data and Subcase Information Entries are specified, and the values of GRID and DOF have to be provided.
- The <filename>_ld.monitor contains the load displacement data of all nonlinear subcases. The file can be read in HyperMesh directly, to visualize the curve.
- NLMON is currently supported Nonlinear static and Nonlinear Transient analysis only. By extension to Nonlinear Transient Analysis, it is also supported for Structural Fluid-Structure Interaction (FSI). NLMON is supported for Nonlinear Optimization runs.
