CFASTG
Bulk Data Entry Defines a fastener which can be used to model connections such as spot welds, rivets, bolts and so on.
| CFASTG | EID | PID | ELSET | REFNODE | CID | INFLRAD | SRCHRAD | ||
| ADJUST | WTMETH | PJID | |||||||
| SURF | ALL or ID1 | ID2 | ID3 | etc. |
Example 1: Automatic Surface Selection
| CFASTG | 22 | 1 | 17 | 2.5 | 10.0 | ||||
| YES | UNIFORM | ||||||||
| SURF | ALL |
Example 2: Surface Selection by SURF Bulk Data Entry ID
| SURF | 20 | 22 | 24 |
| EID | Unique element
| PID | Identification number
of a PFASTG entry. No default (Integer > 0) |
| ELSET | (Optional) References
a JOINTG element ID if this fastener is
modeled explicitly by JOINTG elements.
Default = Blank (Integer > 0) |
| REFNODE | (Optional)
Identification number of a GRID SET ID which defines the
positioning nodes used to define the fastener and to generate
internal JOINTG elements. This field can be
used together with PJID to assign
PJOINTG to internally created
JOINTG elements. Default = Blank (Integer > 0) |
| CID | Identification number
of the coordinate system for this CFASTG
fastener. If this coordinate system field is not defined, an
internal coordinate system is generated based on the positioning
point and surface that the positioning point projected on.
| INFLRAD | Maximum distance from
the projection point on the fastener surface within which the
grids on the surface should lie to be used to generate the
internal RBE3 elements. No default (Real > 0.0) |
| SRCHRAD | (Optional) Search
radius from the positioning point to find the fastening points
on the surfaces. Default = Blank (Real > 0.0) |
| ADJUST | Controls the
adjustment of local Z direction of CID.
| WTMETH | Controls how the
weights are calculated for internally generated
RBE3 elements.
| PJID | (Optional)
Identification number of a PJOINTG entry.
This field can be used in conjunction with the
REFNODE field to assign
PJOINTG property to internally generated
JOINTG elements. If this field is not
defined, the JOINTG entries are defined with
RBEAM type. Default = Blank (Integer > 0) |
| SURF | Continuation line flag to define the surfaces to be connected by CFASTG. The surface IDs are to follow. | |
| ALL or IDi |
- The CFASTG entry is used to define a fastener connection between two surfaces.
- The CFASTG
entry is currently supported for:
- Nonlinear Implicit Analysis
- Explicit Dynamic Analysis
